The thread discusses a friend's laptop overheating during gaming, despite replacing the thermal paste, with temperatures reaching around 87°C for the CPU and 84°C for the GPU. The original poster seeks advice on further cooling solutions, having already suggested a cooling dock. A responder comments that the laptop may not be designed for gaming and notes that the CPU temperature remains within safe limits, recommending software to control fan speeds and confirming that a cooling dock could help. Overall, the tone is informational, and the responses aim to suggest practical steps to mitigate overheating.
shadows
Hi Windows Forum
I'm writing this topic for a friend of mine.
I can start by explaning why I've made this post.
Well you see, my friend has quite some problems with her Laptop, she is experiencing high temperature on her laptop while gaming bf3 on low sittings. She changed thermal paste on her CPU, cleaned all the dust away and done everything she needed to do.
After putting new thermal paste, her temperature goes up to 87 °C (CPU) and 84 °C (GPU).
The picture in this thread shows her specs on her laptop which was taken before she have put new thermal paste on.
Do you guys have any suggestions what else that may cause the temperature raises so much? Or what else she can do to lower the temperature?
I've adviced her to get a cooling docking station for her laptop.
Very Best Regards Shadows / René
Laptops that aren't designed for gaming in mind usually aren't that great for gaming a mainstream title like BF3...
That being said the TJUNCTION of that CPU (the temp at which the cpu-die is considered safe up to, and does not throttle until reached) is 105c which she probably is not hitting (so its running within spec). Which particular laptop is it?
You can try programs such as Speed Fan and enable the system fan at 100% while gaming, and a cooling dock may help.
Josephur
Windows Forum Admin
