rvjimzhr
Well-Known Member
Helping a friend with a HP Pavilion G 6 laptop. Wireless is turned on and off with the F12 button which displays a red light when off and a white light when on. Wireless should toggle on and off by touching this button. It does not. With or without use of the FN key at the bottom of the keyboard. NOTHING we do can get this button to light "white" and allow available wifi connections to display. Reboot....does nothing. Tried air to blow out any dust around the key......nothing. Other FN key functions are working.
Any ideas? Tried the onscreen keyboard for F12....no good. HELP!
Thanks,
Jim
It seems like there are issues with the wireless functionality on your friend's HP Pavilion G6 laptop. Here are some troubleshooting steps you can try to resolve this problem: 1. Update Drivers: - Make sure the wireless network adapter driver is up to date. You can download the latest driver from the HP support website. 2. Check Airplane Mode: - Sometimes, laptops have an "Airplane Mode" feature that disables all wireless connections. Check if this mode is enabled and disable it if necessary. 3. BIOS Settings: - Access the BIOS settings (usually by pressing F10 or another key during boot) and check if the wireless adapter is enabled. Enable it if it's disabled. 4. Physical Inspection: - Ensure that the wireless...
It seems like there are issues with the wireless functionality on your friend's HP Pavilion G6 laptop. Here are some troubleshooting steps you can try to resolve this problem: 1. Update Drivers: - Make sure the wireless network adapter driver is up to date. You can download the latest driver from the HP support website. 2. Check Airplane Mode: - Sometimes, laptops have an "Airplane Mode" feature that disables all wireless connections. Check if this mode is enabled and disable it if necessary. 3. BIOS Settings: - Access the BIOS settings (usually by pressing F10 or another key during boot) and check if the wireless adapter is enabled. Enable it if it's disabled. 4. Physical Inspection: - Ensure that the wireless adapter is properly connected internally. If possible, open the laptop to check if the wireless card is seated correctly. 5. Reset Wireless Adapter: - Try resetting the wireless adapter. You can do this by disabling and re-enabling the wireless adapter in the Device Manager. 6. Reinstall Wireless Adapter: - Uninstall the wireless adapter from the Device Manager and then restart the laptop. Windows should automatically reinstall the driver. 7. HP Wireless Assistant: - Install the HP Wireless Assistant software if it's not already installed. This tool can help manage wireless connections on HP laptops. 8. System Restore: - If the issue started recently, you can try performing a system restore to a point where the wireless functionality was working. 9. Contact Support: - If none of the above steps resolves the issue, it's recommended to contact HP support for further assistance or to repair the hardware if needed. Try these steps and see if they help in getting the wireless functionality back on the HP Pavilion G6 laptop.
