jwill58
Im in need of a good motherboard-not the most expensive-I game some(STALKER-FEAR-BIOSHOCK 2)and watch BluRays. Here is the hardware I have leftover and some of it is new.
AMD Phenom II X4 955 , G.Skill Ripjaws F3-10666CL9D-8GBRL DDR3-1333 4GBx2, PNY GTX275 ,NZXT M-59 case,CORSAIR TX850WATT PSU,WIN 7 Pro 64 bit. I had an MSI K9N2 Diamond. Its gone and Im looking for a change.I'd like to add 4 to 8 more GB of the same G.Skill RAM. I also have a new SSD bootdrive I'd like to try.
(Crucial RealSSD C300 CTFDDAC064MAG-1G1 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) )
I hope Im not asking too much of a noob question-I've built a few riggs so far and they are all still running(except mine) but I would just like some tips from builders more experienced than myself. I've used AS Rock and MSI , and ASUS, they all worked fine.I appreciate any and all suggestions.
Thanks,
jwill58
PS....The sig you see below is the rigg that is no more....I would like a comparable m/b so I wont be taking a step down. Thanks
It's great to hear about your experience in building rigs and your interest in upgrading your motherboard. Based on the hardware you currently have and your requirements for gaming and Blu-ray playback, along with the desire to add more RAM and a new SSD boot drive, here are some recommendations for a motherboard that would be a good fit for your setup:
Motherboard Recommendations:​
  • ASUS M4A79XTD EVO AM3 AMD 790X ATX AMD Motherboard:
  • Compatible with your AMD Phenom II X4 955 processor.
  • Supports DDR3 RAM (up to 16GB).
  • Provides multiple expansion slots for your GTX 275 and additional components.
  • Offers SATA III support for your new SSD boot drive.
  • MSI 870A-G54 AM3 AMD 870 SATA 6Gb/s ATX AMD...
  • MSI 870A-G54 AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard:
  • Supports AM3 processors like your Phenom II X4 955.
  • Has slots for up to 16GB of DDR3 RAM.
  • Features SATA 6Gb/s for faster SSD performance.
  • Offers good compatibility for your existing components.
  • ASRock 870 Extreme3 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard:
  • AM3 socket support for your CPU.
  • Room for up to 16GB of DDR3 RAM.
  • SATA 6Gb/s support for enhanced SSD speeds.
  • USB 3.0 ports for faster data transfer.
    Additional Tips:​
  • Memory Upgrade: Adding 4 to 8 more GB of the same G.Skill Ripjaws RAM is a great idea to boost your system's performance, especially for gaming.
  • SSD Installation: Installing the Crucial RealSSD C300 64GB SSD for your boot drive will significantly improve your system's responsiveness and loading times.
  • Compatibility Check: Ensure the motherboard you choose is compatible with your existing components like the PSU, graphics card, and CPU cooler to avoid any issues.
  • BIOS Update: After installing the new motherboard, make sure to update the BIOS to the latest version for optimal performance and compatibility with newer hardware. By selecting a motherboard from the list above, you can enhance your gaming experience and enjoy smoother Blu-ray playback while utilizing your existing hardware effectively. If you have any specific preferences or requirements, feel free to share them for more tailored recommendations. Happy building!
