nandobadam88
Well-Known Member
- Joined
- Nov 29, 2024
- Messages
- 186
If my hand hits the USB 3.0 enclosure case after ejecting and safely removing hardware in Windows, does this shock cause friction between the 2.5" HDD heads and the magnetic disks?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
SYNCHRONIZE CACHE command to ensure all data stored in the HDD's volatile cache is written to the platters to prevent data corruption.STOP UNIT or STANDBY IMMEDIATE to the HDD via the USB-to-SATA bridge in the enclosure. These commands instruct the drive to:SYNCHRONIZE CACHE:STOP UNIT or STANDBY IMMEDIATE:STOP UNIT or STANDBY IMMEDIATE), the heads remain securely parked until the HDD is reactivated (e.g., when remounted or repowered).STOP UNIT.STOP UNIT and STANDBY IMMEDIATE to the connected HDD.STOP UNIT and STANDBY IMMEDIATE commands, standardized in ATA/ATAPI-6 (2001), are used by all modern HDDs and USB enclosures to achieve safe head parking.STOP UNIT.STOP UNIT, STANDBY IMMEDIATE) supported by Windows and relayed through high-quality enclosures.STOP UNIT and STANDBY IMMEDIATE for head parking.STOP UNIT or STANDBY IMMEDIATE) to the HDD.STOP UNIT), spinning down platters, and processing ATA commands correctly. Commonly found in mid-range to high-end enclosures.STOP UNIT and STANDBY IMMEDIATE: Responsible for head parking and spin-down after ejection.| Chipset | Manufacturer | Typical Usage | Features |
| JMS578 | JMicron | Common in USB 3.0 HDD/SSD enclosures | UASP support, ATA command handling (head parking, spin-down). |
| JMS567 | JMicron | Older USB 3.0 enclosures | Supports USB 3.0 and basic ATA operations. |
| ASM1153E | ASMedia | Mid-range to premium enclosures | UASP support, energy-efficient, compliant with "Safely Remove Hardware" for head parking. |
| PL-2773 | Prolific | Budget USB 3.0 enclosures | Basic USB-to-SATA compatibility, fewer advanced features compared to JMicron or ASMedia. |
STOP UNIT, STANDBY IMMEDIATE) for safe head management during ejection.STOP UNIT: Stops all mechanical operations, parks the heads, and places the drive in a low-power state.STANDBY IMMEDIATE: Safely parks the read/write heads and spins down the platters.STOP UNIT and SYNCHRONIZE CACHE, essential for modern head parking mechanisms.STOP UNIT.STANDBY IMMEDIATE and STOP UNIT, which are used by Windows during safe ejection.STANDBY IMMEDIATE, STOP UNIT) in 2001.| Year | Development |
| Pre-2000 | Basic passive parking for HDDs using mechanical triggers during power-off. |
| 2001 | ATA/ATAPI-6 introduced commands like STOP UNIT for software-triggered head parking. |
| 2001 | Windows XP became the first version of Windows to fully support head parking via "Safely Remove Hardware." |
| 2005 | Universal adoption of head parking in 2.5" HDDs across the major manufacturers for compatibility with ATA commands. |
| HDD Model | Recording Technology | Explanation |
| Seagate ST500LM030 | SMR | Higher storage density with slower write performance for random or heavy workloads. |
| WDC WD10JPVX-08JC3T5 | CMR | Faster, consistent performance for dynamic read/write operations. |
| Hitachi HTS541010A99E662 | CMR | Designed for stability in continuous-use scenarios (e.g., laptops, external drives). |
| Feature | SMR Drives | CMR Drives |
| Cost per GB | Lower (Good for bulk archival). | Higher, but more versatile. |
| Write-Once, Read-Many | Excellent for infrequent writes. | Good, with no write penalties. |
| Write/Update Speed | Prone to slower write performance. | Consistent for random and sequential writes. |
| Long-Term Suitability | Good for static data. | Excellent for all use cases, but pricier. |
SYNCHRONIZE CACHE, STOP UNIT, or STANDBY IMMEDIATE to ensure:STOP UNIT or STANDBY IMMEDIATE command during ejection, parking is executed by the firmware within the HDD itself.STOP UNIT and STANDBY IMMEDIATE commands trigger autonomous head parking.SYNCHRONIZE CACHE: Ensures all data temporarily stored in the drive’s cache is written to the physical platters, preventing data corruption or loss.STOP UNIT or STANDBY IMMEDIATE: Instructs the HDD's firmware to:SYNCHRONIZE CACHE.STOP UNIT or STANDBY IMMEDIATE commands:Load/Unload Cycle Count (SMART Attribute 193):| Step | What It Means |
| Drive Letter Disappears (E | Windows has logically disconnected the drive from the file system. |
| Heads Are Parked | ATA commands issued during safe eject have parked the heads in the safe "parking zone." |
| Platters Are Spun Down | Platters stop spinning or enter a low-power state (managed by the HDD firmware). |
| USB Cable May Remain Connected | The drive is still physically powered by the USB port, but it is in an idle and parked state. |
SYNCHRONIZE CACHE ATA command to ensure all pending data in the cache is safely written to the platters, preventing any data loss.STOP UNIT or STANDBY IMMEDIATE to the HDD. These commands instruct the HDD firmware to:0 indicates no issues.0 value indicates no damage.STOP UNIT) ensures the heads are parked securely away from the platters.| Storage Medium | Lifespan in Archival Use | Durability | Data Retention When Powered Off | Capacity | Cost per GB | Recommendation |
| 2.5" HDD | 5–10 years or more | Moderate (good when idle) | Long (5–10+ years) | High (500GB–5TB) | Low | Best for large datasets in "cold storage" where data is rarely accessed. |
| SSD | 5–10 years (active use) | High (shock-resistant) | Moderate (5–7 years) | Moderate (128GB–4TB) | High | Best for frequent-access archival (e.g., often accessed backups) or environments prone to movement. |
| Pendrive | 1–10 years | Moderate | Short-Moderate (1–5 years) | Moderate (16GB–512GB) | Moderate-High | Only suitable for short-term storage or file transportation. |
| MicroSD Card | Up to 5 years | Low (physical fragility) | Short (1–3 years) | Low (8GB–1TB) | Moderate-High | Use for temporary backups or portable needs, not long-term storage. |
