The thread primarily discusses whether safely removing a USB 3.0 external enclosure with a 2.5" HDD allows the drive's heads to remain parked even if the USB cable stays connected. The consensus is that modern HDDs (including specific models like Seagate ST500LM030, WD10JPVX, and Hitachi HTS541010A99E662) automatically park their heads after the "Safely Remove Hardware" command, with support from compatible USB enclosures using chipsets like JMicron JMS578 or ASMedia ASM1153E. The overall sentiment is that, if properly ejected, the drive's hardware protections prevent head contact during minor shocks, and this functionality has been well-supported since Windows XP in 2001.
