The thread discusses the issue of a missing driver for the Intel Management Engine Interface on a Toshiba Tecra S10 running 64-bit Windows 7. The original poster initially couldn't find a compatible driver, but after trying Vista drivers in compatibility mode and following advice from others, they successfully installed the driver from Toshiba's website, resolving the Device Manager warning. Overall, the user expresses satisfaction with the solution and relief that the device is now properly recognized.
ivanpasic
I've installed 64-bit Windows 7 on my new TOSHIBA Tecra S10 laptop. Installation was smooth, Windows Update was able to locate and download drivers for all the components on my computer save for one. It shows up in my Control Panel as PCI Simple Communications Controller. I've determined that this device is Intel Management Engine Interface. However, I am unable to find a driver (64-bit) for this particular device. It does not seem to affect mu computer at all. I guess I can just wait until Toshiba releases a driver for this device. Does anyone have experience with this issue? Is it OK for me to use my computer without a proper driver for this device? My processor is not going to fry from overheating or something like that, is it?
it worked!
thanks a lot man. on www.toshiba.co.uk i found a 64-bit vista version of the driver for my notebook and followed the instructions posted on the intel web site. i am happy that all the warnings are now gone from my device manager in control panel!
bobkn
At a guess - and I mean guess - you may need to download and install the chipset drivers for the notebook. It may not be necessary, but I believe that it's not likely to do harm.
I'm a bit compulsive, so I prefer to get rid of warnings in Device Manager, even if they never give me any trouble.
ivanpasic
Thread Author #3
thanks, bobkn. i installed windows 7 64-bit chipset drivers from the toshiba web-site but the warning did not go away. toshiba actually offers a driver for Intel Management Engine Interface but it's not available for windows 7 64-bit. i guess i'll just wait.
bobkn
My guess was entirely wrong, it seems.
Intel suggests installing the Vista drivers using Compatibility Mode:
Sorry that I don't have access to a system that would permit me to check that.
Failing that, Intel promises drivers for current products by the time of general availability of Windows 7, and older products by Q1 of 2010.
ivanpasic
Thread Author #5
it worked!
