sillyshy
Is there any software/driver for this mouse it does not work out of box.
I can help you find information about the software or drivers needed for your mouse if it's not working out of the box. Could you provide me with the specific make and model of the mouse you are using so that I can assist you better in finding the required software or drivers?
