fiyaz
I am using Pinnacle PCTV stereo tv tuner card.it works fine in windows xp.in windows 7 i got installed.but i cant select the line-in option in pctv software.no line in option for audio is provided.The main problem is that bcoz of this i cant control volume on my remote.
plz help me out.for controlling volume in XP,a patch was available with the pctv software.but this patch gets installed in windows 7 but no effect.
what should i do to get my line in option on pctv vision software.??
i downloaded realtek for windows 7 for my board.i culdnot configure anything for line in option.
i have stopped using windows 7 bcoz of this...thouch i love windows 7 so much..........anyone plz help me out.........i didnot get any solution from Pinnacle as they have only support for xp.:confused:
It seems like you are experiencing difficulties with your Pinnacle PCTV stereo TV tuner card in Windows 7, particularly in setting up the Line-In option for audio input in the PCTV software. Here are some steps you can take to troubleshoot and potentially resolve this issue:
Troubleshooting Steps:​
  • Driver Update:
  • Ensure that you have the latest drivers for your TV tuner card installed on your Windows 7 system. You can visit the manufacturer's website to download and install the most recent drivers.
  • Compatibility Mode:
  • Try running the PCTV software in compatibility mode for Windows XP. Right-click on the software executable, go to Properties, and in the Compatibility tab, select Windows XP from the...
  • Driver Update:
  • Try running the PCTV software in compatibility mode for Windows XP. Right-click on the software executable, go to Properties, and in the Compatibility tab, select Windows XP from the dropdown.
  • Audio Device Configuration:
  • Check your system's audio settings to ensure that the Line-In or Stereo Mix option is enabled and correctly configured. You can do this in the Sound settings of Windows.
  • Software Patch:
  • Look for any updated patches or software updates specifically for the PCTV software compatible with Windows 7. Sometimes, patches or updates can address compatibility issues.
  • Alternative Software:
  • Consider using alternative TV viewing software that may support Line-In functionality on Windows 7. There are third-party applications that can work with TV tuner cards.
  • Contact Pinnacle Support:
  • Even though Pinnacle might not officially support Windows 7 for your specific model, try reaching out to their support to see if they have any unofficial solutions or workarounds.
  • Community Forums:
  • Look for forums or communities where users might have shared their experiences with similar setups. You might find user-generated solutions or tips.
    Additional Notes:​
  • It's unfortunate that Pinnacle does not provide official support for Windows 7 with your TV tuner model, but exploring these troubleshooting steps might lead to a resolution.
  • Windows 7 is a beloved operating system for many users, so it's understandable that you would want to resolve this issue to continue using it. Feel free to give these suggestions a try, and let me know if you encounter any challenges along the way.
