fifthmanstandin
Question:
I have a computer with an Asus MZN68-LA mobo in it. My friend wanted to add a graph card to his computer. His factory PSU did not have PCI-E plugs to power the graph card so he bought a PSU as well to solve that problem. The new PSU in question is here:
http://www.newegg.com/Product/Produc...82E16817139005
The new PSU fit fine and I began plugging everything up, until I got to the 4 pin ATX12V socket on the motherboard. I realized the new PSU seemingly does not have a single 4 pin ATX12V. There is, however, a black wire/yellow wire (which I take to mean PCI express?) connection that breaks apart from an 8 pin to a 4 pin that would fit fine and, in theory work. What I'm afraid of is having some power supply problem with this massive 650 watt PSU and frying the mobo.
Before I even attempt this, will someone clarify whether or not that's fair game and will work fine?
Question:
The new PSU fit fine and I began plugging everything up, until I got to the 4 pin ATX12V socket on the motherboard. I realized the new PSU seemingly does not have a single 4 pin ATX12V. There is, however, a black wire/yellow wire (which I take to mean PCI express?) connection that breaks apart from an 8 pin to a 4 pin that would fit fine and, in theory work. What I'm afraid of is having some power...
ickymay
Question:
the PCI-e are yellow and black 6+2 pin so its not them, but the atx 12v is two 4 pin connectors and one of them would be fine.
as long as you are matching voltage and observe polarity then the motherboard will simply draw the amperage it needs :)
