maifs
my audio device driver is this:
audiocodec_v680b
it works correctly in xp but doesnt work in WIndows7.
what should i do?
Sorry for the late reply.
A quick Google search says that your drivers are for a device that uses Via Vinyl drivers.
I don't believe that Via has produced Windows 7 drivers for your device, but there appear to be Vista ones. The odds are fairly good that you can use those.
Link Removed - Invalid URLLink Removed - Invalid URL
You'll have to identify your specific chip, as there a couple of different Vista drivers listed under the Vinyl name. (If you've already removed your XP installation, the next place to look would be in your motherboard or notebook PC specifications. Or, search the Web for it, using your exact PC model.)
Hope this helps.
bobkn
Hope this helps.
maifs
i did it all but my sound dirver is not worked still.
help me if you can.
reghakr
Hello and welcome maifs,
Sorry for all the questions, but........
In order to troubleshoot your problem we need to know more detailed specs of your system hardware.
1. Go to Start > Run, and type msinfo32, look under the Components section for hardware identification
2. Go to Control Panel > Device Manager and look for any entry that has a yellow flag beside it
3. The manufacturer name and model number of your PC, if applicable
4 Please fill out your computers specs in the User Control Panel here on the site as well. It will then appear next to your name. look at my posting and you'll see the drop-down arrow.
The exact make and model of your motherboard and video card would be of great help also.
Are you using the 32-bit or 64-bit version?
Was it a "clean" install or an upgrade?
Are you dual-booting?
Are you using the official RC directly from Microsoft?
Did this occur immediately after install?
Do you recall installing any software that may have caused the problem?
maifs
OS Name Microsoft Windows 7 Ultimate
Version 6.1.7100 Build 7100
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name MAIFS-PC
System Manufacturer Gericom
System Model 755CI
System Type X86-based PC
Processor mobile AMD Athlon(tm) XP-M 2600+, 1514 Mhz, 1 Core(s), 1 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 1.04G, 09/07/2004
SMBIOS Version 2.3
Boot Device \Device\HarddiskVolume1
Hardware Abstraction Layer Version = "6.1.7100.0"
Installed Physical Memory (RAM) Not Available
Total Physical Memory 704 MB
Available Physical Memory 347 MB
Total Virtual Memory 1.69 GB
Available Virtual Memory 1.18 GB
Page File Space 1.00 GB
and sound :
Multimedia Audio Controller PCI\VEN_1106&DEV_3059&SUBSYS_81231584&REV_50\3&18D45AA6&0&8D The drivers for this device are not installed.
PCI Simple Communications Controller PCI\VEN_1106&DEV_3068&SUBSYS_40051584&REV_80\3&18D45AA6&0&8E The drivers for this device are not installed.
and DIsplay:
Name Standard VGA Graphics Adapter
PNP Device ID PCI\VEN_1106&DEV_7205&SUBSYS_800A1584&REV_01\4&2FCD0AE0&0&0008
Adapter Type Not Available, (Standard display types) compatible
Adapter Description Standard VGA Graphics Adapter
i am running in a 32 bit.
just a clean install.
yes in a dual boot but now i deleted the earlier version of windows by formatting that drive.
yes after the immediate installation
