ahbee
Hi all,
Anyone have a tutorial about how to use TPM on Windows 7 OS ?
Thanks,
Bee
Hello Bee, Using TPM (Trusted Platform Module) on Windows 7 can enhance the security of your system by providing hardware-based security features. Here's a general guide on how to use TPM on Windows 7:
Steps to Use TPM on Windows 7:​
  • Enable TPM in BIOS:
  • Restart your computer and enter the BIOS settings.
  • Look for the TPM setting and enable it. Save changes and exit BIOS.
  • Initialize TPM in Windows:
  • Press the Windows Key + R, type tpm.msc, and press Enter.
  • Click on "Initialize TPM" to start the initialization process.
  • Follow the on-screen instructions to complete the initialization.
  • Take Ownership of TPM:
  • After initialization, you need to take ownership of the TPM.
  • In...
  • In the TPM Management Console, click on "Change Owner Password" and set the owner password.
  • Enable BitLocker:
  • BitLocker is a drive encryption feature that uses TPM for enhanced security.
  • Open the Control Panel, and click on "BitLocker Drive Encryption".
  • Follow the instructions to enable BitLocker on your desired drives.
  • Manage TPM:
  • You can manage your TPM settings in the TPM Management Console.
  • Here, you can change the owner password, clear TPM, or update settings.
    Note:​
  • Windows 7 support ended on January 14, 2020. It's recommended to upgrade to a more secure and supported version of Windows for ongoing security updates.
  • TPM functionality may vary depending on your hardware and BIOS settings.
  • Always backup important data before making any changes to TPM or encryption settings. By following these steps, you should be able to utilize TPM on Windows 7 effectively. If you encounter any specific issues or need further assistance, feel free to ask for help!
