muhammad77
I have a Hp Mini Notebook 3741-TU. at first it worked with no problems, when I insert a usb cardreader to an existing port on the right ports are still working perfectly. but after I was off and I try to insert usb modem was not working perfectly not even a command that the usb is working or not (zero at all). Until now these ports can not be in use. explanation please, thank you.
It doesn't appear HP has Windows 7 drivers for that system. If you are using ones supplied in Windows 7, they may not be fully functional.
I suppose all I might suggest is to try the Vista Drivers, but if you are using a x64 version of Windows, they may not be allowed.
Also, all the USB ports may not be of the same standard. I do not remember what my Dell's are, different connections may be different versions of USB.
muhammad77
thank you for your concern sir Ralph Bromley ... I have had several checks in the device manager there but I never found any damage (such as there is usually an exclamation mark) and I've also tried a few times some software to check whether there is a problem ... I still do not find the answer.
Saltgrass
You might check the device manager and see if the ports are showing a yellow mark. I noticed on my system, if I removed a card reader/media incorrectly it would deactivate the port. Some devices do not like using a safe removal option.
Rebooting should help if that happens to be the problem.
muhammad77
thank you Saltgrass co ... In essence all I have done no significant change ... at the position facing the monitor at the Hp Mini Notebook I have two usb which previously functioned perfectly. A few minutes ago I tried to move the USB modem in the usb ports that are left to the right ... still no change even after I update to the driver in device manager. I am tired in recent months has tried to solve the problem......:frown:
Saltgrass
