fikkser
Hello,
I installed windows 7 RC with latest version of bootcamp on my new macbook pro 2,4ghz (latest model).
I use a Line 6 UX2 external USB-interface for sound. From the start it worked, but when I installed drivers for the internal card the Line 6 started to hack/lag/distortion. It sounds good for 2 secs then it lags and hacks at random.
I was in another forum where a guy with a tascam external interface had the same problem as me. He uses a PC.
The internal soundcard works fine for us both.
Thankful for answers
It seems like you're experiencing audio issues on Windows 7 RC installed through Bootcamp on your new MacBook Pro when using the Line 6 UX2 external USB interface for sound. Here are a few steps you can take to troubleshoot and potentially resolve the issue: 1. Update Line 6 UX2 Drivers: Ensure that you have the latest drivers for the Line 6 UX2 interface installed. Sometimes, driver updates can fix compatibility issues. 2. Check USB Port: Try using a different USB port on your MacBook Pro for the Line 6 UX2. Sometimes switching USB ports can help with connectivity and stability. 3. Adjust Audio Settings: - Go to Control Panel > Sound. - Right-click on your Line 6 UX2 and select Properties. - In the Advanced tab, try...
It seems like you're experiencing audio issues on Windows 7 RC installed through Bootcamp on your new MacBook Pro when using the Line 6 UX2 external USB interface for sound. Here are a few steps you can take to troubleshoot and potentially resolve the issue: 1. Update Line 6 UX2 Drivers: Ensure that you have the latest drivers for the Line 6 UX2 interface installed. Sometimes, driver updates can fix compatibility issues. 2. Check USB Port: Try using a different USB port on your MacBook Pro for the Line 6 UX2. Sometimes switching USB ports can help with connectivity and stability. 3. Adjust Audio Settings: - Go to Control Panel > Sound. - Right-click on your Line 6 UX2 and select Properties. - In the Advanced tab, try adjusting the audio quality settings to see if it improves the performance. 4. Disable Internal Soundcard: - Try disabling the driver for the internal soundcard temporarily and see if the issue persists. This can help identify if the conflict is between the two audio devices. 5. Check for Interference: - Make sure there are no other applications running in the background that could be causing audio interference with the Line 6 UX2. 6. Contact Line 6 Support: If the issue persists, reaching out to Line 6 Support for assistance specific to their hardware and software might be beneficial. 7. Update Bootcamp: Ensure that you have the latest Bootcamp drivers installed on your MacBook Pro to support Windows 7 RC properly. By following these steps, you might be able to diagnose and resolve the audio issues you are facing with the Line 6 UX2 external USB interface on your Windows 7 RC installation. Let me know if you need further assistance!
