leo morris
- Joined
- Nov 6, 2013
- Messages
- 3
I need help please. I am completely novice, I have a POS software and getting the following error, please help.
A required privilege is not held by the client.
Stack Trace: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Xml.XmlTextWriter..ctor(String filename, Encoding encoding)
at System.Data.DataSet.WriteXmlSchema(String fileName)
at pcAmerica.Desktop.POS.Forms.frmReporting.Report_SALES_CHECK_DETAIL(Int16 method)
Thanks in advance.
Thanks in advance.
