The user reports a Code 10 error with the Killer Wireless 1535 adapter on their Dell XPS 13x after replacing the SSD and reinstalling Windows 10. They suspect the issue might be related to the hardware replacement, possibly affecting the SSD or network adapter, and have attempted driver reinstallation without success. The overall sentiment suggests troubleshooting the wireless adapter or hardware compatibility to resolve the connectivity issue.
Rcups5
I have a Dell XPS 13x I recently replaced the SSD because the old one became corrupted. I then reinstalled Windows 10 and most everything seems fine except for the Wireless Network Adapter that is returning a Code 10: requested operation was unsuccessful when I try to connect to an online network.
The adapter is a Killer Wireless -n/a/ax 1535.
computer specs are as follows
- intel core i5-7200U CPU @ 2.5 GHz
- 8 GB RAM
- 64 bit
Rcups5
Thread Author #2
Note that I had to replace the SSD after trying to stream on twitch. Not sure if this fried my SSD and my adapter, or if at all. I have tried reinstalling the network driver by uninstalling it, and then restarting my computer
