roman12345
i'm using HDMI-DVI cable .we know that DVI are not passing sound and HDMI does, so it create collision and the result of this is strong noise from my TV which be stopped only when i do "mute".
there is another way to stop the noise?
roman12345
no i bought this cable for 15K why should i buy another cable which make the same action?
