The original poster, iRokk, reports a recurring pop-up notification on Windows 8.1 indicating that an audio device is repeatedly plugged and unplugged despite no connection. A responder suggests it could be a driver or hardware issue and provides a link to a potential fix for Realtek audio setups. Overall, the discussion centers on troubleshooting this audio notification problem, with the suggestion leaning towards driver-related solutions.
iRokk
I have 8.1 and I keep getting a pop-up notification for an Audio System Event saying that a device has been plugged in, then unplugged, over and over, when nothing is plugged into the audio jack. Does this sound like a hardware issue or a driver issue? I have looked through a few forums but can't seem to find anyone else having this problem, so any input is appreciated. Thanks!
