OldTimer
Banned
- Joined
- Jul 19, 2010
- Messages
- 798
- Thread Author
- #1
One problem I'm having on Win-8/64 that I'm not having on Win-8/32 is that after I've installed Firefox and then Shockwave and Flash, my browsers are almost catatonic, UN-responsive and in some cases (I.E.) just lock up.
So far, I've determined that UN-installing Shockwave and Flash does improve the situation, but does not cure it 100%.
So if UN-Installing things does not completely fix things, then the only thing left to do is reinstall Win-8, test the browsers and then install one program at a time, testing the browsers after each install to see what program mucks them up.
I'm on Win-8/64 right now and using Firefox. It does work much better now, that I UN-installed both Shockwave and Flash.
I.E. is still in a coma!
I'll be back,
Doc
I'll be back,
Doc
