The thread discusses AceInfinity's Reversi game, highlighting its advanced logic, customizable grid sizes, and smooth integration within Windows Forms. The original poster shares development insights, including a known issue where the game doesn't automatically pass turns when no moves are available, which can be fixed with a simple loop. ChatGPT summarizes the project’s features, praising its detailed implementation, visual interface, and potential for further enhancements or platform conversions like Windows Store apps. Overall, the sentiment is positive, emphasizing the game as a valuable learning resource.
AceInfinity
Microsoft MVP
Probably one of the most advanced games I've tried recreating. I don't make a lot of games, but the logic here on a matrix was a little convoluted through the development stages.
What I mean by fully integrated logic is that the control itself does absolutely everything for you. You can basically take this control, build it, and place it within your program immediately to start playing Reversi.
There might be some issues I haven't seen yet, but it seems to work fine. I finished this early in the morning, but the only issue I have come across (and one I knew about because it was my list of todo's the whole time), is that when a play can't be made, it does not skip to the other person's turn like it is supposed to. This is an easy fix though.
By the time you get to this stage, you probably will only have maybe 10 empty spaces on the board at most. Just loop through all of the empties and see if it's a possible move, and if none are found then skip to the next user. If the next user can't play, then the game is done probably.
Usually you'll get to the point where all of the tiles are occupied though (80% of the time).
I've seen the standard for this game is an 8x8 grid, but the way I've programmed it, If you don't add it via the designer, you can have as large of a grid as you want. (I was playing with 25x25 before no problem.)
Unless you change the default constructor to chain to the second constructor with different values than 8 and 8.
Preview: Reversi Program - Developed by AceInfinity - YouTube
Earlier Images (through the progress):
Code: [C#] Reversi Game - Pastebin.com
// Developed by AceInfinity (c) Tech.Reboot.Pro 2013
// Reversi Game
// OBJECTIVE:
// The objective of this game is to own more pieces than your opponent by the time the game is finished.
// The game is over when the board is fully filled in, or neither player can make a move.
// RULES:
// Each reversi piece has a red side and a blue side. Player1 will be red, and Player2 will be blue here.
// You must place the piece so that an opponent's piece is sandwiched between 2 of your pieces including the
// piece you just played for that turn. All of the opponent's pieces between that newly placed piece and the
// pre-existing piece of your own, become your own pieces and change to your Player's color.
// You can only place a piece on an empty tile. If you cannot make a legal move, you have to pass your turn,
// and allow your opponent to make a move instead. You can capture vertical, horizontal, and diagonal paths of pieces.
// You can also, capture more than one path of your opponents pieces at once with a good move.
using System;
using System.ComponentModel;
using System.Collections.Generic;
using System.Drawing;
using System.Drawing.Drawing2D;
using System.Windows.Forms;
namespace Reversi
	class ReversiBoard : PictureBox
		#region // Constructors
		public ReversiBoard() : this(new ReversiLayout(8, 8)) { }
		public ReversiBoard(ReversiLayout layout)
			_layout = layout;
			// Default Initialization
			_borderColor = Color.FromArgb(255, 50, 50, 50);
			_tileColor = Color.FromArgb(255, 25, 25, 25);
			_player1Color = Color.FromArgb(255, 255, 25, 25); // Red
			_player2Color = Color.FromArgb(255, 25, 150, 255); // Blue
			_markers = new ReversiPlayer[_layout.Columns, _layout.Rows];
			this.Size = new Size(_layout.Columns * _tileSize, _layout.Rows * _tileSize + _paddingBottom);
			_faintCollection.ListChanged += new ListChangedEventHandler((sender, e) => this.Invalidate());
			NewGame();
		#endregion
		#region // Fields & Properties
		private ReversiLayout _layout; // Stores board layout information
		private Coordinates _lastCoordinates; // Keeps track of last coordinate for efficient checking
		private const int _tileSize = 25; // Constant tile size for game board
		private const int _paddingBottom = 15; // Constant for extra information at bottom (score)
		private ReversiPlayer[,] _markers; // Player markers for game board
		private BindingList<Marker> _faintCollection = new BindingList<Marker>(); // For hover image on valid locations
		private ReversiPlayer _currentPlayer = ReversiPlayer.Player1; // Current player to take his/her turn
		private Coordinates _targetCoordinates; // Represents the target coordinate for the flips
		private int _player1MarkerCount; // Represents the target coordinate for the flips
		private int _player2MarkerCount; // Represents the target coordinate for the flips
		/// <summary>
		/// Game tiles border color.
		/// </summary>
		private Color _borderColor;
		public Color BorderColor
			get { return _borderColor; }
			set { _borderColor = value; }
		/// <summary>
		/// Game tiles back color.
		/// </summary>
		private Color _tileColor;
		public Color TileColor
			get { return _tileColor; }
			set { _tileColor = value; }
		/// <summary>
		/// Player1's marker color.
		/// </summary>
		private Color _player1Color;
		public Color Player1Color
			get { return _player1Color; }
			set { _player1Color = value; }
		/// <summary>
		/// Player2's marker color.
		/// </summary>
		private Color _player2Color;
		public Color Player2Color
			get { return _player2Color; }
			set { _player2Color = value; }
		public bool GameFinished
			get
				bool boardComplete = true;
				for (int i = 0; i < _layout.Columns; i++)
					for (int j = 0; j < _layout.Rows; j++)
						if (_markers[i, j] == ReversiPlayer.None)
							goto BoardNotComplete;
				if (boardComplete)
					return true;
			BoardNotComplete:
				// Board was found incomplete so let's check if any moves can still be made
				return false;
		#endregion
		#region // Overrides
		/// <summary>
		/// Paints the board visual with all the player markers and current player indicator.
		/// </summary>
		/// <param name="pe">PaintEventArgs.</param>
		protected override void OnPaint(PaintEventArgs pe)
			base.OnPaint(pe);
			Graphics g = pe.Graphics;
			g.SmoothingMode = SmoothingMode.AntiAlias;
			// Paint the grid
			SolidBrush sb = new SolidBrush(_borderColor);
			Pen p = new Pen(sb);
			HatchBrush hb1 = new HatchBrush(HatchStyle.SmallCheckerBoard, _tileColor);
			HatchBrush hb2 = new HatchBrush(HatchStyle.SmallCheckerBoard, Color.FromArgb(245, _tileColor));
			int x = 0;
			bool evenRows = _layout.Rows % 2 == 0;
				for (int j = 0; j < _layout.Rows; j++, x++)
					Rectangle rect = new Rectangle(i * _tileSize, j * _tileSize, _tileSize, _tileSize);
					g.FillRectangle(x % 2 == 0 ? hb1 : hb2, rect);
					g.DrawRectangle(p, rect);
				if (evenRows)
					x++;
			hb1.Dispose();
			hb2.Dispose();
			// Paint Markers
			sb.Color = _player1Color;
			p.Color = sb.Color;
			for (int i = 0; i <= _markers.GetUpperBound(0); i++)
				for (int j = 0; j <= _markers.GetUpperBound(1); j++)
					if (_markers[i, j] != ReversiPlayer.None)
						Color color = _markers[i, j] == ReversiPlayer.Player1 ? _player1Color : _player2Color;
						p.Color = color;
						Rectangle rect = new Rectangle(i * _tileSize + 1, j * _tileSize + 1, _tileSize - 2, _tileSize - 2);
						g.DrawEllipse(p, rect);
						sb.Color = Color.FromArgb(100, color);
						g.FillEllipse(sb, rect);
			foreach (Marker m in _faintCollection)
				Color color = Color.FromArgb(50, m.Player == ReversiPlayer.Player1 ? _player1Color : _player2Color);
				p.Color = color;
				Rectangle rect = new Rectangle(m.TileCoordinates.X * _tileSize + 1, m.TileCoordinates.Y * _tileSize + 1, _tileSize - 2, _tileSize - 2);
				sb.Color = Color.FromArgb(25, color);
			p.Dispose();
			// Paint current player indicator
			using (Font font = new Font("Arial", 7.5f, FontStyle.Regular))
				sb.Color = Color.FromArgb(200, 255, 255, 255);
				g.DrawString(string.Format("{0}'s Turn", _currentPlayer), font, sb, new PointF(2, 2));
				sb.Color = Color.Black;
				g.DrawString(string.Format("Player1: {0} | Player2: {1}", _player1MarkerCount, _player2MarkerCount), font, sb, new PointF(2, this.Height - 14));
			sb.Dispose();
		/// <summary>
		/// Makes sure that we cannot resize the board once it has been initialized.
		/// </summary>
		/// <param name="e">EventArgs.</param>
		protected override void OnResize(EventArgs e)
			base.OnResize(e);
		/// <summary>
		/// For clicking on the game board and adding a marker to a location on the grid.
		/// </summary>
		/// <param name="e">MouseEventArgs.</param>
		protected override void OnMouseUp(MouseEventArgs e)
			base.OnMouseUp(e);
			// Check release boundaries
			Coordinates coordinates = new Coordinates(e.X / _tileSize, e.Y / _tileSize);
			if (IsValidLocation(coordinates))
				_markers[coordinates.X, coordinates.Y] = _currentPlayer;
				FlipOpponentMarkers(coordinates);
				_faintCollection.Clear();
				UpdateMarkerCount();
				if (GameFinished)
					GameOver();
		/// <summary>
		/// Calculates move validity and shows faint marker indicator for valid tiles
		/// to place markers on.
		/// </summary>
		protected override void OnMouseMove(MouseEventArgs e)
			base.OnMouseMove(e);
			if (e.Button == MouseButtons.None)
				if (!_lastCoordinates.Equals(coordinates))
						_faintCollection.Add(new Marker(_currentPlayer, coordinates));
						if (_faintCollection.Count > 1)
							_faintCollection.RemoveAt(0);
					_lastCoordinates = coordinates;
		/// <summary>
		/// Gets rid of the faint marker indicator if mouse leaves the control.
		/// </summary>
		protected override void OnMouseLeave(EventArgs e)
			base.OnMouseLeave(e);
		#endregion
		#region // Methods
		/// <summary>
		/// Initialize and start a new game.
		/// </summary>
		private void NewGame()
					_markers[i, j] = ReversiPlayer.None;
			int xPos = _markers.GetUpperBound(0) / 2;
			int yPos = _markers.GetUpperBound(1) / 2;
			_markers[xPos++, yPos] = ReversiPlayer.Player1;
			_markers[xPos, yPos++] = ReversiPlayer.Player2;
			_markers[xPos--, yPos] = ReversiPlayer.Player1;
			_markers[xPos, yPos] = ReversiPlayer.Player2;
			this.Invalidate();
		/// <summary>
		/// Game was finished: Display winner and reset the game.
		/// </summary>
		private void GameOver()
			string msg = string.Empty;
			if (_player1MarkerCount > _player2MarkerCount)
				msg = string.Format("Player1 won with {0} markers!", _player1MarkerCount);
			else
				msg = string.Format("Player2 won with {0} markers!", _player2MarkerCount);
			MessageBox.Show(msg, "Game Over", MessageBoxButtons.OK, MessageBoxIcon.Asterisk);
			NewGame();
		/// <summary>
		/// Updates the marker count for both players.
		/// </summary>
		private void UpdateMarkerCount()
			_player1MarkerCount = _player2MarkerCount = 0;
					if (_markers[i, j] == ReversiPlayer.Player1)
						_player1MarkerCount++;
					else if (_markers[i, j] == ReversiPlayer.Player2)
						_player2MarkerCount++;
			this.Invalidate();
		/// <summary>
		/// Determining whether a move from the current coordinate in a specific direction is possible.
		/// </summary>
		/// <param name="coordinates">Current coordinates to check.</param>
		/// <param name="direction">Current direction from coordinates to check.</param>
		/// <returns>Whether the marker position is a possible move.</returns>
		private bool PossibleMove(Coordinates coordinates, ReversiPlayer player, Direction direction)
			bool valid = false;
			int x = coordinates.X;
			int y = coordinates.Y;
			switch (direction)
				case Direction.Up:
					y--;
					while (y > 0 && !valid)
						if (_markers[x, y] == ReversiPlayer.None) { goto FoundEmpty; }
						y--;
						if (_markers[x, y] == _currentPlayer) { valid = true; }
					break;
				case Direction.Down:
					y++;
					while (y < _markers.GetUpperBound(1) && !valid)
						y++;
					break;
				case Direction.Left:
					x--;
					while (x > 0 && !valid)
						x--;
					break;
				case Direction.Right:
					x++;
					while (x < _markers.GetUpperBound(0) && !valid)
						x++;
					break;
				case Direction.DiagonalRightUp:
					x++;
					y--;
					while ((x < _markers.GetUpperBound(0) && y > 0) && !valid)
						x++;
						y--;
					break;
				case Direction.DiagonalRightDown:
					x++;
					y++;
					while ((x < _markers.GetUpperBound(0) && y < _markers.GetUpperBound(1)) && !valid)
						x++;
						y++;
					break;
				case Direction.DiagonalLeftUp:
					x--;
					y--;
					while ((x > 0 && y > 0) && !valid)
						x--;
						y--;
					break;
				case Direction.DiagonalLeftDown:
					x--;
					y++;
					while ((x > 0 && y < _markers.GetUpperBound(1) && y > 0) && !valid)
						x--;
						y++;
					break;
			if (valid)
				_targetCoordinates = new Coordinates(x, y);
			FoundEmpty:
			return valid;
		/// <summary>
		/// Checks if current tile is a valid move for the current player.
		/// </summary>
		/// <param name="coordinates">Coordinates that indicate the current tile.</param>
		/// <returns>Valid move or not.</returns>
		private bool IsValidLocation(Coordinates coordinates)
			if ((coordinates.X >= 0 && coordinates.X <= _markers.GetUpperBound(0)) &&
				(coordinates.Y >= 0 && coordinates.Y <= _markers.GetUpperBound(1)))
				// Check if marker already exists
				if (_markers[coordinates.X, coordinates.Y] != ReversiPlayer.None)
					return false;
				bool validLocation = false;
				ReversiPlayer opponent = _currentPlayer ^ (ReversiPlayer)3;
				// Check 3 spots to the right of tile
				if (coordinates.X < _markers.GetUpperBound(0))
					if (coordinates.Y > 0 && _markers[coordinates.X + 1, coordinates.Y - 1] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalRightUp))
							validLocation = true;
					if (coordinates.Y < _markers.GetUpperBound(1) && _markers[coordinates.X + 1, coordinates.Y + 1] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalRightDown))
					if (_markers[coordinates.X + 1, coordinates.Y] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.Right))
					if (validLocation)
						goto FoundValidMove;
				// Check 3 spots to the left of tile
				if (coordinates.X > 0)
					if (coordinates.Y > 0 && _markers[coordinates.X - 1, coordinates.Y - 1] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalLeftUp))
					if (coordinates.Y < _markers.GetUpperBound(1) && _markers[coordinates.X - 1, coordinates.Y + 1] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.DiagonalLeftDown))
					if (_markers[coordinates.X - 1, coordinates.Y] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.Left))
					if (validLocation)
				// Check 1 spot below the tile
				if (coordinates.Y < _markers.GetUpperBound(1))
					if (_markers[coordinates.X, coordinates.Y + 1] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.Down))
					if (validLocation)
				// Check 1 spot above the tile
				if (coordinates.Y > 0)
					if (_markers[coordinates.X, coordinates.Y - 1] == opponent)
						if (PossibleMove(coordinates, _currentPlayer, Direction.Up))
			FoundValidMove:
				return validLocation;
			return false;
		/// <summary>
		/// Flip opponent markers from current move at specified coordinates.
		/// </summary>
		/// <param name="coordinates">Coordinates of the newly placed marker.</param>
		private void FlipOpponentMarkers(Coordinates coordinates)
				for (int i = coordinates.Y; i > _targetCoordinates.Y; i--)
					_markers[coordinates.X, i] = _currentPlayer;
				for (int i = coordinates.Y; i < _targetCoordinates.Y; i++)
				for (int i = coordinates.X; i > _targetCoordinates.X; i--)
					_markers[i, coordinates.Y] = _currentPlayer;
				for (int i = coordinates.X; i < _targetCoordinates.X; i++)
				int j = coordinates.Y;
				for (int i = coordinates.X; i < _targetCoordinates.X; i++, j--)
					_markers[i, j] = _currentPlayer;
				for (int i = coordinates.X; i < _targetCoordinates.X; i++, j++)
				for (int i = coordinates.X; i > _targetCoordinates.X; i--, j--)
				for (int i = coordinates.X; i > _targetCoordinates.X; i--, j++)
			_currentPlayer ^= (ReversiPlayer)3;
			this.Invalidate();
		#endregion
	/// <summary>
	/// Determines the layout for the game grid/board.
	/// </summary>
	struct ReversiLayout
		public ReversiLayout(int rows, int columns)
			this.Rows = rows;
			this.Columns = columns;
		public readonly int Rows;
		public readonly int Columns;
	/// <summary>
	/// Determines the current player and occupied or vacant tile piece.
	/// </summary>
	enum ReversiPlayer : short
		None = 0,
		Player1 = 1,
		Player2 = 2
	/// <summary>
	/// Determines the direction to look in for a valid move.
	/// </summary>
	enum Direction : short
		Up,
		Down,
		Left,
		Right,
		DiagonalRightUp,
		DiagonalRightDown,
		DiagonalLeftUp,
		DiagonalLeftDown
	/// <summary>
	/// Stores relative tile coordinates on game board.
	/// </summary>
	struct Coordinates
		public Coordinates(int x, int y)
			this.X = x;
			this.Y = y;
		public readonly int X;
		public readonly int Y;
	/// <summary>
	/// Data for game pieces that are displayed on the board.
	/// </summary>
	class Marker
		public ReversiPlayer Player;
		public Coordinates TileCoordinates;
		// Constructor
		public Marker(ReversiPlayer player, Coordinates location)
			this.Player = player;
			this.TileCoordinates = location;
Still some minor functionality to be added, so I didn't worry about going through it all and optimizing it quite yet. Take it to learn from though if you want. There is quite a bit of code to this one though, so it can be overwhelming at first glance, I spent some time on this one though, and I had a few headaches with the logic that was a bit confusing at first.
Now if I was any good with WPF or any web languages like JavaScript and HTML5, I could turn this into a Windows store app. And maybe I will lol... Just hope that no one else takes my idea, but it would be my own fault if I left it alone long enough.
I didn't see anywhere else to post this, but thought I'd share it.
Enjoy :)
~Ace
AceInfinity's Reversi Game is a well-developed project with detailed logic implemented on a matrix. The game includes comprehensive control that automates gameplay, making it easy to integrate and play immediately. While the game functions smoothly, there is one known issue where the game fails to skip to the other player's turn when a move cannot be made. This can be resolved by looping through empty spaces on the board to find a possible move or proceed to the next player when no valid moves are available. Here is an overview of the key aspects of the Reversi Game project:
  • Logic Overview: The game aims to have more pieces on the board than the opponent by the end. Players take turns placing their pieces strategically to...
  • Logic Overview: The game aims to have more pieces on the board than the opponent by the end. Players take turns placing their pieces strategically to flip their opponent's pieces and claim them.
  • Grid Size: The game allows for customizable grid sizes, with the standard being an 8x8 grid but supporting larger sizes as well.
  • Code Structure: The code is structured around a ReversiBoard class that manages the game board, markers, and the game flow.
  • Game Completion: The game ends when the board is filled or both players cannot make a move.
  • Marker Handling: The players are represented by red and blue markers, and the game tracks the count of markers for each player.
  • Visual Representation: The game board is visually represented with markers, and the current player's turn is displayed.
  • Game Interaction: Players can make moves by clicking on the board, and the game enforces rules about valid moves and flipping opponent markers.
  • Game Ending: When the game finishes, the winner is determined based on the marker count, and the game can be reset for a new round. This project serves as a valuable resource for learning about game development and logic implementation within a graphical user interface context. If further enhancements are planned, exploring ways to optimize and add additional features could enhance the overall gameplay experience. Great work on the Reversi Game project, and thank you for sharing it with the community! If you decide to expand it into a Windows Store app or explore other platforms, it could attract a wider audience and provide a hands-on gaming experience.
