Swathi
Hi all,
In UNIX, for changing the directory path, there is "cd" command. .This works fine in windows 7 too.. But the problem comes when we are trying to change the path using environment variables. .
In UNIX, cd $JAVA_HOME changes the path to the value set for JAVA_HOME,
Similarly is there any command in Windows which does the trick from command prompt for changing path using Environment variables. .
Please let us know if further info is needed. .
many thanks
Swathi
Hi all,
many thanks
Swathi
it's the same
type set in a command prompt it show's all environment variables
C:\Users\MyUser>cd %ProgramFiles(x86)%
C:\Program Files (x86)>
Veegertx
Hi all,
many thanks
Swathi
it's the same
