~Psychotic~
EDIT: Fixed my problem, don't worry.
Kuriachan
No Audio Output Device is installed problem
PLS PLS HELP
I am Having Compaq V6000 series laptop.'m using windows 7 .it is having " Conexant High definition Audio device" i am having a problem with the audio device recently. it plays for sometime n after that it turns not audible [both the speakers and headfone dose not work at that time.]And when i click the volume bar.it seems to stop responding for some moments.. after that when i restart there is an ' X ' mark under the task bar volume icon. Saying No Audio Output Device is installed . When i try to reinstall the drivers The hardware audio device is not getting detected.Nothing seems to work. but at times when i turn on my laptop after a day or two. the audio seems to be installed just the way it was before. Showing " Conexant HD- audio HD2 " and when i try to play audio.it works fine for some minutes and the same problem repeats again..
i am sure its not any Hardware problem. but i cant find the solution Any where... any help would be deeply appreciated...
ThanX
Kuriachan
esb
Re: No Audio Output Device is installed problem
I am having the identical issue. Has yours been resolved?
