The user initially experienced display issues with icons and elements in Internet Explorer, which did not occur in Edge. After resetting IE settings, the problem temporarily resolved but later reappeared, suggesting a conflict between Windows graphics and forum graphics. Other users using different browsers, like Chrome, did not encounter the issue, and the original poster ultimately resolved the problem by adjusting IE options.
- Joined
- May 1, 2008
- Messages
- 5,546
OK. Problem corrected (But not solved)
Went right through the settings and coudnt see any problems. So did a complete reset of IE, and all was back to normal. - I'll never know!! Only seemed to happen on this site??
- Joined
- May 1, 2008
- Messages
- 5,546
Understand. This is not bothering me, but curiosity has got under my skin.
Just had a look at a couple of other computers I use. differenet modelels and , probably, different specs.
All are showing those tow icons and the items when trying to post. Just don't get it.
Judging by the feedback, noone else has had this experience?
