The original poster, khaledur123, reports that their E drive, which contained important data, suddenly disappeared, leaving them locked in their admin account and seeking help. Respondents explain that logical drives cannot be simply deleted like files; instead, issues may stem from formatting, partition removal, or hardware failure, and suggest checking Disk Management. Additionally, they mention that drive letter reassignment could be a cause if hardware changes occur, such as switching USB sticks. Overall, the thread discusses possible reasons why the drive disappeared and troubleshooting steps.
khaledur123
So my E drive had a lot of important things and all of a sudden it was deleted, it contained my account inside so I am now stuck in my Admin account. Is there any way to help me get my drive back? It is a hard drive. Please help me
Logical drives can't be deleted the same way as a file or directory. It can be formatted, the partition removed or the drive has gone bad. Does the disk still show up in 'Disk Management'
Neemobeer
Windows Forum Team
ussnorway
Windows Forum Team
it can also be reassigned so for example if your software saves to a Usb stick as E then you remove the stick and replace it with a different usb stick they may both be assigned as E
