guren2
Whenever I try to install, an error comes up saying: your computer can;t run this version of windows. you need an installation disc that's compatible with your computer. For more information, check your computer's system information. I have a 32 bit iso and my computer is a 32 bit OS. and it is build 7232
jeradw
it almost sounds like you have the 64 bit ISO and your pc is only 32 bit compatible. What are your specs for your pc? Where did you get your ISO?
busydog
My 7232 is an X64. I don't recall an X86 7232 so you likely have an X64 disk trying to upgrade X86.
