The thread discusses a user experiencing delayed system startup, with high hard drive activity lasting about two minutes after login, despite efforts to disable startup programs and update drivers. The user has ruled out hardware issues, including hard drive problems, and considers their system's slow boot time abnormal, especially compared to a similar netbook that boots in under a minute. Contributors suggest checking for software conflicts, updating drivers, and using monitoring tools like ProcessMonitor to diagnose high disk usage during startup, indicating that while some solutions are offered, the user remains determined to resolve the issue.
Mitchell_A
Former Moderator
Everytime I start Windows, for almost 2 minutes after login, the hard drive read-writes are completed maxed out. MSE and what not starts before then, but Messenger, browsers etc can't be started until the load drops off some. I've attached my bootlog and system info, as requested by TorrentG. You all know I'm quite savvy and can try pretty muchly anything to keep solve the problem. I've already tried all the obvious things - disabling start-up programs and services (essentially to the barebone point) and even went through the paiun of disabling hundred of individual DLL's and executables using Autoruns.
TIA for any help :)
Link Removed - Invalid URL
I have an older Dell laptop that does the same thing when MSE is installed. My other machines work OK with MSE.
Uninstall MSE and see if that is the problem. On the laptop I use Avast and Malwarebytes and all is good.
Joe S
What software do you have that automatically checks for updates on boot up? On mine Avast and Comodo both do and Comodo holds things from connecting first. Do you have any automatic back up set up? The Smartware that came with my WD external drive maxed out my ram on start up and I've got 8 G.
Joe
Mitchell_A
Former Moderator
Thread Author #4
There's the attachment - nothing runs at startup other than MSE and Messenger (and a few other things like Launch Manager for touch buttons).
Anyway, there's the attachment in the OP.
Nothing updates at startup, that is for sure.
Jimbo22
when trying to open the attachment it's asking us to save it first before we can look at it. I don't need to save it just look at it. I have seen this with most of your attachments as well. I'm not sure as to how to fix the attachment problem your having or if your aware of it.
TorrentG
Banned
Broadcom NetLink (TM) Gigabit Ethernet driver is from June 10, 2009 which is before Windows 7 RTM was even created.
You can update this from here - Link Removed
Atheros AR5B93 Wireless Network Adapter driver has an update to apply - Link Removed
Alps touchpad driver can use an update - Link Removed
Update for the Conexant modem drivers:
Update for the card reader drivers:
When done with all that, I'd use something like O&O Defrag on the hard drive, after cleaning its files and registry with Ccleaner.
Mitchell_A
Former Moderator
Thread Author #7
Didn't think to update drivers.
disk is defragged at 12 am every sunday using defraggler, and I try to run CCLeaner at least once a week.
Updated all the drivers, Still no success.
Jimbo22
Was this a recent problem or has it been going on for some time? How about a system restore?
TorrentG
Banned
Hey Mitchell. I was looking online about your particular model. There might be variants of it, but for the most part, it seems to be high low-end spec machine about in the $400 US price range.
Perhaps it is normal for that machine to take about a good 2 minutes to boot to working desktop. I would tend to think so since your troubleshooting steps and updating drivers combined did not seem to help much at all.
My father has a netbook which I setup completely myself on a formatted hard drive. There's no bloatware or anything like that. It's has all my personal speed tweaks etc..
It still takes a little over 2 full minutes to get to a working desktop from a cold boot state.
Hope this helps somewhat.
Another idea I just had is that you could install ProcessMonitor and put a shortcut to it in the startup folder. Upon a reboot, you can use to to see what exactly is using the hdd i/o to such a high extent. Let us know what you find and we'll see if it's normal or not, and if there's something that could be done about it.
Mitchell_A
Former Moderator
Thread Author #10
Even from a reboot state running at about 50 degress ~ it still takes a long time to fully load. My specific model was $600 CAD.
I ran extensive HDD tests, surface and full, so it's definitely not my hard drive.
When i run that program at startup, do I need to save the log or something and add it as an attachment?
**EDIT**
My netbook, with essentially the same software setup, boots and is ready to go in 48 seconds average, so I won't take no for an answer :p
Mitchell_A
Former Moderator
Thread Author #11
Also, if it's worth mentioning, this turns up in the event logs a few times every day:
The driver detected a controller error on \Device\RaidPort0.
TorrentG
Banned
No guarantees this is going to be of much help, but it actually might be. Open an elevated command prompt and run this command from it:
chkdsk /r
It will take some time so start the command, follow the simple instructions about rebooting and then let it be until completion. Probably best to do before you go to sleep or something.
Mitchell_A
Former Moderator
Thread Author #13
Have run disk check several times, really no help.
I'm swapping this HDD for an SSD soon, in hopes that will fix the problem.
TorrentG
Banned
Yeah, that definitely will.
I still recommend trying O&O on the drive to defragment it. A "space" type of defragmentation would do well. It has excellent algorithms that may make a nice difference in the time it takes for Windows to access all the files it needs while booting.
The software is extremely smart to know what would be best and does this.
Here's a free trial:
O&O Software - O&O Defrag 12 Pro
You'll gain best results by doing an offline type of defrag too. This will defrag the files it can't touch in Windows, which is a very important process for speed.
If you use it, I would disable the Windows Defrag service and the service(s) of the other defrag software you have installed.
dmillerhsv
Mitchell_A
Former Moderator
Thread Author #16
Interesting.. Have beta 2.0 of MSE.
I will uninstall and see if that makes a difference. :)
Mitchell_A
Former Moderator
Thread Author #17
I uninstalled.. just a slight difference that was to be expected.
I think it's some sort of hardware conflict.
Mitchell_A
Former Moderator
Thread Author #18
Actually, after uninstalling again I think I've noticed a significant difference. Will try from cold boot soon..
Thanks :D
**EDIT**
Think this is pretty much busted, time to switch to a different AV. Shame, as Microsoft Security Essentials is one of the best IMO.
