The original poster asks if there's a way to increase OneDrive upload speeds on their Windows 8.1 Pro laptop, expressing dissatisfaction with their current upload speed of 0.53 Mbps. A forum member responds that upload speeds mainly depend on the user's ISP plan and hardware, recommending a speed test to gauge their internet performance. The overall sentiment indicates the user is seeking solutions or software to improve upload speed, but the main advice emphasizes that ISP limitations primarily determine upload rates.
nvdanh1997
Hi, I'm a new member in this forum. My laptop is running Windows 8.1 Pro. I wonder that are there any ways to increase the upload speed of Onedrive? Is there a software can solve this problem? Tks! 🙂
upload speeds are based on 2 very important factors; hardware and your ISP, but mainly your ISP (internet service provider). You upload speed is set by your ISP based on the plan you have with them. To get a good idea what your DL/UL speeds are, run speedtest.net in your browser.
http://www.speedtest.net/
Jimbo22
