The thread discusses issues with installing and running the 64-bit version of iTunes on Windows 7 x64 RC1. The original poster reports that despite installing iTunes64, it installs into the x86 directory and functions as a 32-bit application, causing freezing problems. A second user confirms they are experiencing the same problem, indicating a recurring issue with the compatibility of iTunes 64-bit on this Windows 7 build.
Slashmolder
I found Link Removed due to 404 Error but it didn't work.
I'm running Win7 x64 RC1.
When I try to install iTunes64 it installs to the x86 directory and is most defiantly the 32 bit installation. I get some issues with iTunes freezing whenever I try to use the 32 bit iTunes. I was before using the Beta 1 of Windows 7 and iTunes x64 installed perfectly for me (in 64 bit mode).
no123one
I have the exact same problem.
