U
Unregistered
Guest
I just installed RC1 and my HP notebook which has Go7200. The website said it is Vista Capable and when I ran Vista Adviser it also said it is no problem.
However Vista detect it as Standard VGA and even I downloaded and run the nVIDIA driver it said that no driver for this device.
Anyone can help?
Uninstall the device, then reboot, then install it upon reboot with the new driver... DO NOT allow it to auto-install the driver for you.. telll it where the driver is. Hope that helps. (assuming you didn't already do this)
Khan
