Kyle Padlan
Please help me im having problems running some .exe files.. look at the pictureLink Removed
here are my specs :
System Information
Time of this report: 8/5/2012, 21:01:19
Machine name: KYLEPADLAN-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7600) (7600.win7_gdr.120503-2030)
Language: English (Regional Setting: English)
System Manufacturer: Acer
System Model: Aspire 4755
BIOS: AcerSystem v2.2
Processor: Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz (8 CPUs), ~2.2GHz
Memory: 4096MB RAM
Available OS Memory: 3908MB RAM
Page File: 1594MB used, 6217MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7600.16385 32bit Unicode
I see that you're experiencing issues running some .exe files on your Windows 7 Ultimate 64-bit system. Here are some steps you can take to troubleshoot this: 1. Compatibility Mode: Try running the .exe files in compatibility mode. Right-click on the .exe file, go to Properties, then the Compatibility tab. Check the box that says "Run this program in compatibility mode for," and select an earlier version of Windows. 2. Check for Malware: It's possible that the .exe files are being blocked by antivirus software or due to malware on your system. Run a full antivirus scan to ensure your system is clean. 3. Update Drivers: Ensure that all your drivers, especially graphics drivers, are up to date. Outdated drivers can...
I see that you're experiencing issues running some .exe files on your Windows 7 Ultimate 64-bit system. Here are some steps you can take to troubleshoot this: 1. Compatibility Mode: Try running the .exe files in compatibility mode. Right-click on the .exe file, go to Properties, then the Compatibility tab. Check the box that says "Run this program in compatibility mode for," and select an earlier version of Windows. 2. Check for Malware: It's possible that the .exe files are being blocked by antivirus software or due to malware on your system. Run a full antivirus scan to ensure your system is clean. 3. Update Drivers: Ensure that all your drivers, especially graphics drivers, are up to date. Outdated drivers can sometimes cause issues with running certain applications. 4. Check for Windows Updates: Make sure your Windows operating system is up to date by checking for and installing any available updates. Some updates may include fixes that address compatibility issues. 5. Run as Administrator: Try running the .exe files as an administrator. Right-click on the .exe file and select "Run as administrator." 6. System File Checker: Use the System File Checker tool to scan for and repair corrupted system files. Open a command prompt as an administrator and type sfc /scannow. 7. Check Event Viewer: Look in the Event Viewer for any error messages related to the .exe files. This can provide more specific information on what might be causing the problem. 8. Reinstall the Software: If the .exe files are associated with specific software, try uninstalling and reinstalling the software to see if that resolves the issue. 9. Check for System Integrity: Use the chkdsk command to check your disk for errors and the DISM tool to repair Windows system image integrity. After trying these steps, if you're still having trouble running the .exe files, please provide more details or error messages so we can assist you further.
