Spiros accidentally deleted the Atheros network driver on his X54H laptop, losing internet access. Kemical provided a download link and suggested checking Device Manager to confirm the network chip's status. Spiros expressed gratitude after finding the correct driver, and kemical acknowledged his update positively.
Hi Spiros,
as we discussed in the pm this is your download page:
http://www.asus.com/uk/Notebooks_Ultrabooks/X54H/HelpDesk_Download/
I know you say you installed the Atheros driver can you check in Device manager to see if your network chip is running. Device manager can be found via the control panel.
- Joined
- Aug 28, 2007
- Messages
- 36,163
Hi Spiros,
