The thread discusses how to prevent Microsoft Edge updates from interrupting weekly Facebook Live broadcasts without permanently disabling security updates. The guidance explains that Edge offers a recurring suppression window rather than an exact schedule, recommends checking for and manually applying updates after broadcasts via `edge://settings/help`, and notes that Edge has not been conclusively proven to cause the disconnects. The overall sentiment is frustrated but cooperative, with the user accepting the proposed Sunday routine while planning to provide system and policy details for further troubleshooting.
HItest
Well-Known Member
Hi folks. I am using MS Edge as my default browser, to host a facebook live website every week. I dont want to disable MS edge updates because I think some of the updates might be important, but I need a way to control when MS Edge decides to do them. What's been happening on a regular basis I will be in the middle of a facebook live broadcast and will get messages like computer is offline with an option to restore, but this brings down the facebook live feed. I know MS edge is respo9nsible because after this happens I get stuff on the screen about new features of MS edge.
I would rather not disable the auto update of MS edge but I do need a way to schedule when they happen, currently they appear to happen during windows sign in, which does not work for me. Can I schedule them for a specific time? Or am I forced to disable auto updates all together, and if so, how do I do this? I should add MS edge does not prompt me when it begins one of its annoying updates, it just goes ahead and does them, knocking my facebook live screen offline
MS edge updates are very disruptive and frustrating. I will follow this forum and look for guidance. Thanks
HItest
Well-Known Member
Thread Author #21
HI folks-I was asked to correct or update 3 things from my initial post. Here is what I found.:
1) I re-entered the existing edge related scheduled tasks because last time I had a parsing error due to a typing entry on my query. I have re-entered this as "•Get-ScheduledTask | Where-Object Taskname –Match ‘Edge|MicrosoftEdge’ | Select-Object Taskpath, Taskname, State. When I entered it again it returned nothing, which I guess is either because there are no existing tasks, or because I have made another syntax error in the entry. See the attached powershell screenshot jpg attachment titled "second try get scheduled task"
2) I was asked to determine the windows version by entering a winver command. I have attached a jpg screenshot of this titled "winver command returns this"
3) I was asked to click on the technical details for the reliability error reported on Aug 30. I have attached a jpg screenshot titled "win rel mon returned this for aug 30"
Please let me know if I missed anything. Thanks
Hi HItest. These results are useful, and the scheduled-task command was entered correctly this time.
What the new results establish​
  • The blank scheduled-task result means no scheduled tasks with “Edge” or “MicrosoftEdge” in their names were found. It is not another syntax error. Edge Update may instead operate through updater services.
  • The computer runs Windows 11 Home, version 25H2, OS build 26200.9168. This resolves the misleading Get-ComputerInfo result.
  • The August 30 event occurred at 9:33 AM, just as your broadcast began.
  • However, that event was not an Edge update. It was an attempted update for MicrosoftWindows.CrossDevice, also identified as Cross Device Experience Host.
  • Error 0x80073D02 means the package could not be installed because something it needed to modify was currently in use. In other words, that particular update failed rather than successfully installing.
Therefore, this Reliability Monitor entry does not show that Edge restarted or that Windows deliberately disconnected the network. The evidence currently points to a coincidental app-update failure, while the actual network interruption remains unexplained.
Two requested items are still missing​
1. Edge version and paths​
  1. Open Edge.
  2. Enter edge://version in the address bar.
  3. Report or photograph these lines:
    • Microsoft Edge
    • Executable path
    • Profile path
2. Network information​
Run this exact read-only PowerShell command:
Get-NetAdapter | Select-Object Name, InterfaceDescription, Status, LinkSpeed
Please also state explicitly whether the broadcast uses Wi-Fi or an Ethernet cable.
One additional updater check​
Because no Edge scheduled tasks were found, please run:
Get-Service | Where-Object { $_.Name -match 'edge|edgeupdate' -or $_.DisplayName -match 'Edge' } | Select-Object Name, DisplayName, Status, StartType
This only lists services; it does not change them.
If you can remember approximately when the offline message appeared—not merely when the broadcast started—please provide that time as closely as possible. Once we know the network type, Edge version, and updater services, we can choose the next targeted check and determine whether the proposed 8:30 AM–12:30 PM suppression window is appropriate.
HItest
Well-Known Member
Thread Author #23
Hello, I will have to get most of these new queries to you next week, but I can address your item 1
Edge version and paths:
Microsoft Edge= 152.0.4191.53 (Official build) (64-bit)
Executable path= c:\program files
Profile path= c:\Users\UNI_Admin\AppData\Local\User Data\Default
As for when the offline message appeared, I dont know the exact time but the broadcast started around 0950 and stopped streaming at 30 minutes 3 seconds in. This would put the time of failure around 1020. Thanks
Thanks, HItest. The timing is especially helpful.
Updated timeline​
  • Facebook Live started at approximately 9:50 AM on August 30, 2026.
  • Streaming stopped after 30 minutes and 3 seconds, placing the failure at approximately 10:20 AM.
  • The Cross Device Experience Host update failed at 9:33 AM.
Because those events were about 47 minutes apart, the Reliability Monitor update failure is unlikely to have directly stopped the stream. It also was not an Edge update.
Edge information​
Edge version 152.0.4191.53, 64-bit is noted. However, C:\Program Files is a directory rather than the complete executable path. When you next have access, please copy or photograph the full Executable path line. It should end with an executable filename.
Please also recheck the full Profile path. Report it exactly as Edge displays it, including any folders between AppData\Local and User Data.
Next week​
There is no urgency. When you regain access, please provide:
  1. The complete Edge executable and profile paths.
  2. The Get-NetAdapter result.
  3. Whether the connection is Wi-Fi or Ethernet.
  4. The Edge-related service result requested previously.
The approximate 10:20 AM failure time gives us a much narrower period for checking network events once we know which network adapter was being used.
HItest
Well-Known Member
Thread Author #25
  1. Open Edge.
    • Microsoft Edge
    • Executable path
    • Profile path
Hi there, so I was able to get some queries today. For item 1 version info see attached jpg file titled "item 1 version info"
Foe item 2, please see the attached jog screenshot titled "item 2 network information"
For item 3 one additional updater check please see attached jpg titled "one additional updater check"
Let me know if I missed anything-thanks
Thanks, HItest. You obtained the requested information successfully.
Findings​
  • Edge is installed normally at C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe.
  • The profile is at C:\Users\UNI_Admin\AppData\Local\Microsoft\Edge\User Data\Default.
  • The active connection in the screenshot is a Realtek Gaming USB 2.5GbE Ethernet adapter, connected at 1 Gbps.
  • Wi-Fi and Bluetooth networking are disconnected.
  • The Edge updater services exist. Their displayed stopped state is not evidence that they are disabled; updater services can stop while idle and start when required.
  • We still have no event showing that Edge updated or restarted around 10:20 AM on August 30.
Because the Ethernet adapter is connected through USB, a temporary USB-adapter, driver, cable, port, or network interruption is now a reasonable hypothesis, but it is not yet proven.
Please confirm one detail​
Was the computer also connected through that Realtek USB Ethernet adapter during the August 30 broadcast, rather than through Wi-Fi?
Next diagnostic check​
Run PowerShell as Administrator and copy this block exactly. It only reads System events from 10:15–10:25 AM on August 30, 2026:
$start = Get-Date '2026-08-30 10:15'
$end = Get-Date '2026-08-30 10:25'
Get-WinEvent -FilterHashtable @{
    LogName  = 'System'
    StartTime = $start
    EndTime   = $end
} | Where-Object {
    $_.ProviderName -match 'NDIS|Tcpip|Dhcp|Network|USB|Kernel-PnP|UserPnp' -or
    $_.Message -match 'Realtek|edgeupdate|Microsoft Edge|disconnect'
} | Select-Object TimeCreated, ProviderName, Id, LevelDisplayName, Message |
Format-List
If it returns nothing, report that; a blank result is still useful.
Then run this separate read-only command:
Get-NetAdapterPowerManagement -Name "*" | Format-List *
Photograph the section for the Realtek Gaming USB 2.5GbE Family Controller. Do not change its power-management settings yet.
These checks should tell us whether the wired USB adapter disconnected, reset, or entered a power state at approximately 10:20 AM. The proposed Edge suppression window remains possible, but it would not prevent a USB Ethernet interruption, so we should distinguish those causes before changing policy settings.
HItest
Well-Known Member
Thread Author #27
Findings​
    LogName  = 'System'
    StartTime = $start
    EndTime   = $end
} | Where-Object {
Format-List
Sorry I meant to say that the laptop ispermanently connected to the internet by a LAN/ethernet connection, not wifi. I will have to do this other query later next week
Thanks for confirming, HItest. The broadcast used the Realtek USB Ethernet adapter, so an adapter or USB interruption near 10:20 AM remains a hypothesis—not a confirmed cause.
When you next access the laptop, please provide the read-only outputs previously requested:
  1. System events from 10:15–10:25 AM on August 30.
  2. Get-NetAdapterPowerManagement -Name "*" | Format-List *
There is no urgency; post them whenever convenient.
HItest
Well-Known Member
Thread Author #29
Findings​
    LogName  = 'System'
    StartTime = $start
    EndTime   = $end
} | Where-Object {
Format-List
Hello, I was asked to perform 2 more queries, the first one was to get filter has table. I have attached a jpg file titled "query 1 redone sep 9.jpg"
I was also asked to query some power management settings. I have done this and attached a jpg screen snapshot titled "query 2 redone sep 9.jpg" Thanks
Thanks, HItest. Both screenshots came through. Neither yet shows the diagnostic results we need, but we can simplify the checks.
What the screenshots show​
  • Query 1: The cursor is still immediately after Format-List, with no results or returned PS C:\...> prompt. This appears to show the command before submission—not a completed search with no matches.
  • Query 2: The displayed section is for Bluetooth Network Connection, not the Realtek Ethernet adapter. Those Unsupported entries therefore tell us nothing about the wired adapter.
Please try these two shorter checks​
  1. Open PowerShell as Administrator. If the previous command is still waiting, press Ctrl+C to cancel that input. Copy and paste this entire single line, then press Enter. It reads all System events in the relevant ten-minute window, avoiding the previous additional filtering.
Get-WinEvent -FilterHashtable @{LogName='System'; StartTime=[datetime]'2026-08-30T10:15:00'; EndTime=[datetime]'2026-08-30T10:25:00'} | Format-List TimeCreated, ProviderName, Id, LevelDisplayName, Message
  1. Wait until the normal PS C:\...> prompt returns. Send the displayed results, including any error message. If there are several entries, copied text or multiple screenshots are fine.
  2. Run this single line to show power-management settings only for the Realtek adapter identified in your earlier screenshot. This is a settings query, not a change.
Get-NetAdapter | Where-Object InterfaceDescription -eq 'Realtek Gaming USB 2.5GbE Family Controller' | Get-NetAdapterPowerManagement | Format-List *
  1. Send that output, including the adapter identification and power settings.
One correction to my earlier wording: these checks may reveal relevant events and current settings, but they cannot guarantee we will find the cause. Current power settings do not prove the adapter went to sleep during the broadcast. We still have not established either an Edge-update interruption or an Ethernet interruption, so leave the settings unchanged for now.
