The user initially inquired about enabling a notification for the Caps Lock status, as the indicator light was not working. Neemobeer provided a third-party solution that displays an icon in the system tray to indicate Caps Lock status, which the user reported trying without initial success. However, after further attempts, the user confirmed that the solution is now working correctly, expressing gratitude.
msnarayanan
Well-Known Member
dear all
The cap lock pop up is not showing nor the light glowing in the cap lock button.
In the absence of this, it is very difficult to enter case sensitive passwords.
I am short of ears and unable to hear beep sound.
I shall be thankful if you will let me know how to enable pop up appears when the cap lock is on.
Thanks
M S Narayanan
I don't know if anything exists for that.
I wrote this for you though.
Unzip and copy it to C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup and it should run on start up.
On start up it will show up in your system tray like this.
An image from 'Capital lock'. Icons indicate Caps Lock status as ON (green) or OFF (red), with an exit option shown.
When caps lock is turned on
When caps is turned off
If you want to close it, right click the icon and select exit
Neemobeer
Windows Forum Team
msnarayanan
Well-Known Member
Thread Author #6
Dear Sir
I retried it and I am glad to inform you that it is working fine.
Thanks
M S NARAYANAN
