The thread discusses the challenge of recovering Edge browser bookmarks after a Windows 10 reset, with the original poster seeking solutions. Contributors suggest using data recovery tools like Recuva and attempting to restore bookmarks from backups or cloud sync, but acknowledge these methods may not always succeed if backups weren’t made beforehand. Overall, the discussion emphasizes the importance of regular backups for bookmarks to prevent data loss in such situations.
Hermitkrab
Hello, Guys. I recently restored my PC and lost all bookmarks in my Edge Browser (shoulda backed 'em up). Is there any way to restore them? Thanks.
Toshiba laptop
Windows 10, version 1709
OK. In the event of you wanting to restore/reinstall, or whatever. You should, in the first instance, make a copy of the folde. It's here:
C:\Users\username\AppData\Local\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe\AC\MicrosoftEdge\User\Default\Favorites
In their usual contrary way, MS chose to bury it real deep
Neemobeer
Windows Forum Team
That guide assumes you backed them up. You can run a tool like Recuva, GetDataBackNTFS or testdisk to try and recover the directory where they are stored which is mentioned in that article linked above.
Hermitkrab
Thread Author #4
Thnks for your reply, Neemo. The problem is my bookmarks weren't backed up, so there's no place from which I can recover them. Funny, I've done resets before and I think, though not sure, that the browsers remained intact.
Neemobeer
Windows Forum Team
You can attempt to recover them from the deleted partition. That is what the tools I mentioned will do.
davehc
There is a remote possibility that they were stored, in the cloud, for IE. Try the Edge import facility with IE selected as the source.
Hermitkrab
Thread Author #7
Neemo:I tried Recuva but was unsure where to tell it to look. I tried C:// but tens of thousands of files were located. I also tried 'documents' with same result. To go through all those files would be pretty daunting. Anyhow, thanks for mentioning Recuva. I'm keeping the program for possible future use.
DaveHC: I tried importing from IE but none of the bookmarks were mine.
I'm not going to be too concerned. Fortunately, I've remembered most of my important bookmarks and reinstated them in my browser.
davehc
helpifIcan
Fantastic Member
Sad thing also is if you had another win10 PC and they were set to sync the reset would have deleted the favorites on the other PC.
The sync always looks at the last operation on synced PCs and migrates to all others, at least this is the way it works on my 3 win10 PCs.
Make sure once you get them back you do the backup.
If some of these came from either Firefox or IE explorer you may be able to get some of them back with what Neemobeer suggested. In these explorers they are not buried so deep. For instance in IE it is you user directory and just favorites.
Just to save me grief I backup the favorites on a regular basis, good luck.
Hermitkrab
Thread Author #10
"Just to save me grief I backup the favorites on a regular basis, good luck." Amen. Lesson earned.
