The original poster asks if it's possible to set default volume levels for individual programs in Windows, specifically wanting certain apps to have a lower volume regardless of the system-wide volume setting. ChatGPT responds by suggesting third-party software options, such as EarTrumpet or CheVolume, and explains methods like using the Windows volume mixer or virtual audio cables to manage app-specific volumes independently. The overall discussion indicates that achieving this customization requires additional software or configuration, as Windows doesn't natively support setting default per-application volume levels.
fumblemuffin
This isnt a problem so much as a question. I have my volume set to 80, but I only want a few programs to actually be at that volume; mainly voice chat programs. I have everything else set to 30. I was wondering if there is a way to set the default volume for new programs to be 30, even though my system volume is set to 80.
To control the volume levels for individual programs independently of the system volume in Windows, you can consider using third-party volume control software or a virtual audio cable to route specific programs through different audio channels or adjust their volume levels separately. Here's a general idea of how you might achieve this: 1. Third-Party Audio Control Software: Some software applications allow you to manage and adjust the volume levels for individual programs. These types of tools enable you to control the sound levels of various applications independently. Examples include EarTrumpet, CheVolume, and Audio Switcher. 2. Virtual Audio Cable: A virtual audio cable can route audio output from specific applications...
To control the volume levels for individual programs independently of the system volume in Windows, you can consider using third-party volume control software or a virtual audio cable to route specific programs through different audio channels or adjust their volume levels separately. Here's a general idea of how you might achieve this: 1. Third-Party Audio Control Software: Some software applications allow you to manage and adjust the volume levels for individual programs. These types of tools enable you to control the sound levels of various applications independently. Examples include EarTrumpet, CheVolume, and Audio Switcher. 2. Virtual Audio Cable: A virtual audio cable can route audio output from specific applications to different audio channels or devices. By using a virtual audio cable, you can control the volume of each channel separately. This method might require some configuration and setup to ensure it works correctly. 3. Audio Mixer Settings: Windows has a built-in audio mixer where you can adjust the volume settings for different applications. To access the audio mixer, right-click the speaker icon in the system tray and select "Open Volume Mixer." From there, you can adjust the volume levels of individual applications. 4. Audio Equalizer Software: Some audio equalizer software allows you to set presets or profiles for different applications. By creating custom profiles, you can adjust the volume settings and other audio parameters for specific programs. By using these methods or a combination of them, you should be able to achieve the goal of having different volume levels for various programs while maintaining the system volume at a different level. It might take some experimentation and configuration to find the best solution for your specific setup and requirements.
