MIRKOSOFT
Active Member
Hi!
AFAIK Hyper-V is bare virtualization without using OS like host. This is difference between VMware or VirtualBox.
I need for testing physical hardware for several purposes like hardware driver doesn't work in new update and in previous was working.
Instead installing secondary OS I want to test driver or other hardware in Hyper-V.
Is possible to use for example PCIe device to detect in guest?
Or for some reasons some hardware working in very old versions. Here's also Q - is possible to allow direct disk access?
Thank you for each help, reply, suggestion or comment.
Miro
All hypervisors rely on an OS VMware ESX is an OS, but fairly minimal to allow more resources for virtualization. Hyper-v and VMWare ESX are referred to as type 1 hyper visors where as VMware player or Virtual box are type 2 (applications that sit on an OS)
You can allow access to different hardware devices to the guest OSes. You can also do pass-thru disk access in Hyper-V.
As an example for Server 2012R2 Migrate Pass-Through Disk Storage by Using Hyper-V in Windows Server 2012 R2
Neemobeer
Windows Forum Team
MIRKOSOFT
Active Member
Ok, what with devices like PCIe or other connected, except USB and similar?
Miro
Neemobeer
Windows Forum Team
You can pass-thru storage, USB and graphics cards possibly others I don't work with Hyper-V a lot.
