The original poster, Basx19, is seeking help to revert from the Windows 11 Insider Preview build to a stable version or Windows 10, as the usual method of leaving the Insider Program in settings didn't work. A responder suggests using the 'Leave the Insider Program' option in settings, but Basx19 reports that this method is ineffective. The thread reflects frustration with the process, indicating a need for alternative solutions to exit the Insider build and install a regular version of Windows.
Basx19
Hello everyone,
I enrolled myself for the dev-program of Windows 11. After a lot of updates, my laptop has the Buils 22478.rs_prerelease.211008-1414 version of Windows 11.
I want to have the normal version of windows 11 and I don't want to get al these dev builds. How can I lose this version and go back to Windows 10 or get the real version of Windows 11?
I already did a clean install but this only removed my programs, but the version is still the same.
I hope someone can help me because it is driving me nuts.
Greetings,
Bas
Neemobeer
Windows Forum Team
In settings under 'Windows Insider Program' there is a link to leave the insider program. That should be all that is required.
Basx19
Thread Author #3
Unfortunately, that doesn't work. It does not give me the option to the normal version of Windows 11
