Myobi
Hello, I installed windows 7 this weekend... until now everything was great. Today I went to school and tried to connect to the internet through my mobile modem, the problem is it keeps dectecting the modem and then it just vanish's... then it detects it again! and just keeps doing it. It seems its something related to the "Data Interface", any suggestions? =/
It sounds like you're facing an issue with your Windows 7 system connecting to the internet through your mobile modem. When the modem is detected but then disappears repeatedly, it could be related to the drivers or the configuration of the data interface. Here are a few steps you can take to troubleshoot this issue: 1. Check Device Manager: - Press Windows Key + R to open the "Run" dialog. - Type in devmgmt.msc and press Enter to open Device Manager. - Look for any devices with exclamation marks or question marks, indicating driver issues. 2. Update Drivers: - Right-click on the problematic device in Device Manager and select "Update Driver Software." - Choose to search automatically for updated driver software...
It sounds like you're facing an issue with your Windows 7 system connecting to the internet through your mobile modem. When the modem is detected but then disappears repeatedly, it could be related to the drivers or the configuration of the data interface. Here are a few steps you can take to troubleshoot this issue: 1. Check Device Manager: - Press Windows Key + R to open the "Run" dialog. - Type in devmgmt.msc and press Enter to open Device Manager. - Look for any devices with exclamation marks or question marks, indicating driver issues. 2. Update Drivers: - Right-click on the problematic device in Device Manager and select "Update Driver Software." - Choose to search automatically for updated driver software. If a new driver is found, let Windows install it. 3. Reinstall Modem Software: - Uninstall the modem software from the Control Panel. - Reinstall the latest software and drivers provided by the modem manufacturer. 4. Check Network Settings: - Open Network and Sharing Center from the Control Panel. - Click on "Change adapter settings" on the left-hand side. - Right-click on your modem connection and select "Properties." - Ensure that the settings are correct and try disabling and re-enabling the connection. 5. Test with Another USB Port: - Sometimes issues can arise from a faulty USB port. Try using a different USB port to connect your mobile modem. 6. Reset TCP/IP Stack: - Open Command Prompt as an administrator. - Type the following commands one by one and press Enter after each:
 netsh int ip reset netsh winsock reset
7. Check for Windows Updates: - Make sure your Windows 7 system is up to date by checking for and installing any available Windows updates. 8. Run Troubleshooters: - Windows has built-in troubleshooters that can help identify and fix common connectivity issues. You can access them in the Control Panel. After trying these steps, restart your computer and see if the issue persists. If you continue to experience problems, it's a good idea to contact your mobile modem provider for further assistance or consider seeking help from a technical support professional.
