The thread discusses a Windows startup issue where the user experiences inconsistent boot behavior, including BIOS and blue screens, with a POST bleep indicating a potential hardware or configuration fault. The original poster is concerned about preserving data and seeks a fix without reinstalling Windows. A responder advises that the POST bleep suggests a hardware or configuration problem and recommends taking the PC to a repair shop rather than attempting software reinstallation.
Boomerang Gaming
Well-Known Member
My PC is not starting up as it should. Sometimes it just defaults to the Bios screen, other times it defaults to the blue sign-in screen but without the p/w box, other times it goes to blue screen and freezes immediately I enter p/w, and sometimes it just starts normally. It can take me 3 -8 attempts of powering down and starting before I can log-in and use the computer. There is a POST bleep most of the times I try to start. The PC uses an SSD. i9.11 and has 80gb Ram and approx 8TB disk space.
Is there a way of fixing this? I have so much on my system I do not really want to do a new install.
