The original poster, janyc12, is seeking help with saving a movie project created in Movie Maker 2.6 on Windows 7, as the software doesn't support saving movies on this OS. They inquire whether downloading the Movie Maker 2.6 enhancement pack would enable them to save their project as a movie without starting over or switching programs. A responder suggests that, according to a referenced page, Windows 7 compatibility might be achieved through the enhancement pack, offering a potential solution.
janyc12
I have Windows 7 and I created a movie using movie maker 2.6. Once I was finished editing, after 30+ hours, movie maker wouldn't let me save as a movie - apparently Windows 7 isn't supported by it.
I found the movie maker 2.6 enhancement pack. If I download this, will I be able to take my file that I made and now save as a movie in Windows 7?
Any help would be appreciated. I spent so much time on this and hope there's a way I can turn this into a movie without starting all over and using a different program like live movie maker.
Thanks!
well according to this page it's 7 compatible so the enhancement might just be what your after..
Link Removed - Invalid URL
