The original poster inquires whether installing Windows 98 on an older Windows Vista laptop will overwrite Vista or be possible at all, aiming to help their grandson with a robotics kit that requires Windows 98. A respondent doubts the laptop's compatibility with Windows 98 and requests additional details about the laptop's make and the robotics hardware to offer better advice. Overall, the discussion centers on hardware compatibility concerns and the need for specific information to determine whether installing Windows 98 is feasible.
bozonoz
without going in to gory details.....I have an older laptop with windows vista on it. I need to put windows 98 on it. if I download windows 98 will it override the windows vista? will windows vista, even, allow me to try and do this?
I need this done to help my grandson who has an older robotics kit, but in order to make it work, he needs a computer with windows 98 on it.
thank you for your time and suggestions.
bill
new Orleans
I am an older guy and not a tech savvy individual...so I would appreciate any advice in simple terms. thank you again.
I doubt very much that the laptop would be Windows 98 compatible. Can you post the make and model of the laptop as well as what it is Robotics wise your trying to run (old modem?)
