Patrick1812
I have looked absolutely everywhere, and cannot find a solution to this problem. Ive tried everything related to simple settings in Internet File Explorer, but I cant select files in between two check marks like I was able to do before. The only thing I haven't done that was suggested was to do a HKEY registry edit. Which strikes me as dangerous and suspicious.
Please help...
ussnorway
Windows Forum Team
post a screengrab or vid please
we need to see what is happening
Patrick1812
Shouldnt it let me select every thing in between two check marks ?
Patrick1812
Ok when I hold shift and drag a blue box it will select them all. Is that how its supposed to work ?
ussnorway
Windows Forum Team
Yes if you draw a box around them or shift click the thumbnails it select all
Click the tick boxes = just wanted that one
Sent from my R8A using Windows Forums mobile app
