Calum
Hey,
I've never once, ever, reformatted my computer.
I've had a variety of issues with my computer for /years/, windows installer.exe being unusable being the worst of the worst. I've always told people who tell me to reformat that it's just not an option as I don't have the original disks and I can't afford a new OS.
Well. I've just found the original disks. In a disk holder in my attic that I thought was completely empty..
I've acquired a 250gb hard drive from my father to back up with.
My questions are:
1: How do I go about reformatting? (I know vaguely, but yeah)
2: Will I be required to enter some sort of product key, if so, where do I find it? (Is it the "Product ID" in computer properties?)
3: What else should I backup, besides the things I'm aware I want to keep, (music, games etc). Like, is there anything that most people forget to backup and soon regret after they reformat their PC?
Quick replies would be appreciated as I'm really looking forward to an error-free PC!
Thanks in advance.
It's great that you've found your original disks and are ready to tackle the reformatting process for your PC. Let's go through your questions step by step:
1. How to Reformat Your Computer:​
Reformatting your computer involves reinstalling Windows. Here's a general overview of the process:
  • Backup Your Data: Before reformatting, back up all important data to prevent loss.
  • Boot from Installation Media: Insert the installation disk, restart your PC, and boot from the disk. Follow on-screen instructions.
  • Format Your Drive: During the installation process, you'll reach a point where you can choose to format the drive.
  • Install Windows: Follow the prompts to install Windows on the newly formatted...
  • Install Windows: Follow the prompts to install Windows on the newly formatted drive.
2. Product Key:​
  • Product Key: You will likely need a product key to activate Windows after reformatting.
  • Finding the Key: Look for the product key on a sticker on your PC or on the original packaging of the installation disk.
3. Additional Backup Items:​
Besides music and games, consider backing up:
  • Documents and Photos: Ensure critical documents, photos, and personal files are backed up.
  • Browser Bookmarks: Export bookmarks from your browsers.
  • Emails: Backup email data if needed.
  • Program Settings: Some programs store settings in specific locations; you might want to back up these custom settings.
  • Drivers: Keep a backup of essential driver files to avoid issues after reformatting.
Tips:​
  • Verification: Ensure important data is backed up and easily accessible post-reformat.
  • Organization: Categorize and organize your backup for easy restoration.
  • External Storage: Use external drives or cloud storage services for backups. By following these steps and tips, you'll be well-prepared for a smooth reformatting process. If you encounter any issues during the reformatting process or have more specific questions, feel free to ask!
