superstrikertwo
I just installed Windows Vista Premium Home Edition today and I have no sound. I ran a dixdag so I could see what my sound card was but it said I don't have one. Before the upgrade I had sound now I have none. How do I fix this?
Here is my DixDag:
System Information
Time of this report: 2/3/2007, 23:15:58
Machine name: GIZMO-JR
Operating System: Windows Vistaâ„¢ Home Premium (6.0, Build 6000) (6000.vista_rtm.061101-2205)
Language: English (Regional Setting: English)
System Manufacturer: Gateway
System Model: MX6429
BIOS: Rev 1.0
Processor: AMD Turionâ„¢ 64 Mobile Technology ML-32, ~1.8GHz
Memory: 446MB RAM
Page File: 709MB used, 731MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 10
DX Setup Parameters: Not found
DxDiag Version: 6.00.6000.16386 32bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: RADEON XPRESS 200M Series (Microsoft Corporation - WDDM)
Manufacturer: ATI Technologies Inc.
Chip type:
DAC type: Internal DAC(400MHz)
Device Key: Enum\PCI\VEN_1002&DEV_5955&SUBSYS_0300107B&REV_00
Display Memory: 127 MB
Dedicated Memory: 63 MB
Shared Memory: 64 MB
Current Mode: 1280 x 800 (32 bit) (60Hz)
Monitor: Generic PnP Monitor
Driver Name: atiumdag.dll,atiumdva.dll,atitmmxx.dll
Driver Version: 7.14.0010.0449 (English)
DDI Version: 9Ex
Driver Attributes: Final Retail
Driver Date/Size: 12/5/2006 22:53:14, 2494464 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B71EE2-1A15-11CF-0A72-0A23A1C2CA35}
Vendor ID: 0x1002
Device ID: 0x5955
SubSys ID: 0x0300107B
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel: ModeMPEG2_A ModeMPEG2_C
Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
{3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAXâ„¢ 2.0 Listen/Src: No, No
I3DL2â„¢ Listen/Src: No, No
Sensauraâ„¢ ZoomFXâ„¢: No
Sound Capture Devices
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1002, 0x4375
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 11/2/2006 00:55:21, 191488 bytes
| Driver: usbd.sys, 11/2/2006 00:55:00, 5888 bytes
+-+ Logitech USB Cordless Mouse
| | Vendor/Product ID: 0x046D, 0xC501
| | Matching Device ID: usb\vid_046d&pid_c501
| | Service: HidUsb
| | Driver: hidusb.sys, 11/2/2006 00:55:01, 12288 bytes
| | Driver: hidclass.sys, 11/2/2006 00:55:01, 38912 bytes
| | Driver: hidparse.sys, 11/2/2006 00:55:00, 25472 bytes
| | | Matching Device ID: hid\vid_046d&pid_c501
| | | Service: mouhid
| | | Driver: mouhid.sys, 11/2/2006 00:51:12, 15872 bytes
| | | Driver: mouclass.sys, 11/2/2006 01:49:54, 31848 bytes
Hi superstriketwo, try this Gateway support page and you should be able to find the drivers needed for your set up. It is possible that the reason why the dxdiag is not picking up your sound card is until it's had the device drivers installed your machine won't 'see' it..
superstrikertwo
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 11/2/2006 00:51:13, 54784 bytes
| Driver: kbdclass.sys, 11/2/2006 01:49:57, 32872 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
+ PS/2 Compatible Mouse
| Matching Device ID: *pnp0f13
| Service: i8042prt
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: termdd.sys, 11/2/2006 01:50:28, 50792 bytes
| Driver: sermouse.sys, 11/2/2006 00:51:11, 19968 bytes
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 25.2 GB
Total Space: 50.2 GB
File System: NTFS
Model: HTS421260H9AT00 ATA Device
Drive: D:
Free Space: 4.4 GB
Total Space: 7.0 GB
File System: FAT32
Drive: E:
Model: PHILIPS DVD+-RW SDVD8820 ATA Device
Driver: c:\windows\system32\drivers\cdrom.sys, 6.00.6000.16386 (English), 11/2/2006 00:51:44, 67072 bytes
System Devices
Name: Broadcom 802.11g Network Adapter
Device ID: PCI\VEN_14E4&DEV_4318&SUBSYS_000617F9&REV_02\4&445E9A7&0&10A4
Driver: C:\Windows\system32\DRIVERS\BCMWL6.SYS, 4.82.0028.0056 (English), 11/1/2006 23:30:53, 464384 bytes
Name: Marvell Yukon 88E8036 PCI-E Fast Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4351&SUBSYS_0300107B&REV_10\4&2EF67FE1&0&0030
Driver: C:\Windows\system32\DRIVERS\yk60x86.sys, 9.00.0032.0003 (English), 11/1/2006 23:30:56, 194048 bytes
Name: SDA Standard Compliant SD Host Controller
Device ID: PCI\VEN_104C&DEV_8034&SUBSYS_0300107B&REV_00\4&445E9A7&0&4CA4
Driver: C:\Windows\system32\DRIVERS\sdbus.sys, 6.00.6000.16386 (English), 11/2/2006 00:35:12, 82432 bytes
Name: Texas Instruments PCIxx21 Integrated FlashMedia Controller
Device ID: PCI\VEN_104C&DEV_8033&SUBSYS_0300107B&REV_00\4&445E9A7&0&4BA4
Driver: C:\Windows\system32\DRIVERS\tifm21.sys, 2.00.0000.0006 (English), 7/6/2006 11:44:00, 168448 bytes
Name: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8032&SUBSYS_0300107B&REV_00\4&445E9A7&0&4AA4
Driver: C:\Windows\system32\DRIVERS\ohci1394.sys, 6.00.6000.16386 (English), 11/2/2006 00:55:16, 62080 bytes
Driver: C:\Windows\system32\DRIVERS\1394bus.sys, 6.00.6000.16386 (English), 11/2/2006 00:55:12, 53376 bytes
Name: Texas Instruments PCIxx21 Cardbus Controller
Device ID: PCI\VEN_104C&DEV_8031&SUBSYS_0300107B&REV_00\4&445E9A7&0&48A4
Driver: C:\Windows\system32\DRIVERS\pcmcia.sys, 6.00.6000.16386 (English), 11/2/2006 01:51:12, 167528 bytes
Name: AMD Miscellaneous Configuration
Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&13C0B0C5&1&C3
Driver: n/a
Name: AMD DRAM and HyperTransport™ Trace Mode Configuration
Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&13C0B0C5&1&C2
Driver: n/a
Name: AMD Address Map Configuration
Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&13C0B0C5&1&C1
Driver: n/a
Name: AMD HyperTransport™ Configuration
Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&13C0B0C5&1&C0
Driver: n/a
Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_5A3F&SUBSYS_0300107B&REV_00\3&13C0B0C5&1&08
Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.00.6000.16386 (English), 11/2/2006 01:50:57, 140392 bytes
Device ID: PCI\VEN_1002&DEV_5A38&SUBSYS_59501002&REV_00\3&13C0B0C5&1&30
Name: RADEON XPRESS 200M Series (Microsoft Corporation - WDDM)
Device ID: PCI\VEN_1002&DEV_5955&SUBSYS_0300107B&REV_00\4&2A5B5026&0&2808
Driver: n/a
Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1002&DEV_5950&SUBSYS_0300107B&REV_10\3&13C0B0C5&1&00
Driver: n/a
Name: AC97 Soft Data Fax Modem with SmartCP
Device ID: PCI\VEN_1002&DEV_4378&SUBSYS_0300107B&REV_02\3&13C0B0C5&1&A6
Driver: n/a
Name: ATI I/O Communications Processor LPC Controller
Device ID: PCI\VEN_1002&DEV_4377&SUBSYS_0300107B&REV_00\3&13C0B0C5&1&A3
Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.00.6000.16386 (English), 11/2/2006 01:49:20, 13928 bytes
Name: Standard Dual Channel PCI IDE Controller
Device ID: PCI\VEN_1002&DEV_4376&SUBSYS_0300107B&REV_00\3&13C0B0C5&1&A1
Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.00.6000.16386 (English), 11/2/2006 01:49:20, 13416 bytes
Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.00.6000.16386 (English), 11/2/2006 01:50:18, 42600 bytes
Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.00.6000.16386 (English), 11/2/2006 01:49:36, 19048 bytes
Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.00.6000.16386 (English), 11/2/2006 01:50:41, 107112 bytes
Name: ATI I/O Communications Processor USB 1.1 OHCI controller
Device ID: PCI\VEN_1002&DEV_4375&SUBSYS_0300107B&REV_00\3&13C0B0C5&1&99
Driver: C:\Windows\system32\drivers\usbohci.sys, 6.00.6000.16386 (English), 11/2/2006 00:55:05, 19456 bytes
Driver: C:\Windows\system32\drivers\usbport.sys, 6.00.6000.16386 (English), 11/2/2006 00:55:11, 223744 bytes
Driver: C:\Windows\system32\drivers\usbhub.sys, 6.00.6000.16386 (English), 11/2/2006 00:55:21, 191488 bytes
Device ID: PCI\VEN_1002&DEV_4374&SUBSYS_0300107B&REV_00\3&13C0B0C5&1&98
Name: ATI I/O Communications Processor USB 2.0 EHCI controller
Device ID: PCI\VEN_1002&DEV_4373&SUBSYS_0300107B&REV_00\3&13C0B0C5&1&9A
Driver: C:\Windows\system32\drivers\usbehci.sys, 6.00.6000.16386 (English), 11/2/2006 00:55:04, 38400 bytes
Driver: C:\Windows\system32\hccoin.dll, 6.00.6000.16386 (English), 11/2/2006 01:46:05, 8704 bytes
Name: ATI I/O Communications Processor SMBus Controller
Device ID: PCI\VEN_1002&DEV_4372&SUBSYS_0300107B&REV_11\3&13C0B0C5&1&A0
Driver: n/a
Name: ATI I/O Communications Processor PCI Bus Controller
Device ID: PCI\VEN_1002&DEV_4371&SUBSYS_00000000&REV_00\3&13C0B0C5&1&A4
Name:
Device ID: PCI\VEN_1002&DEV_4370&SUBSYS_0300107B&REV_02\3&13C0B0C5&1&A5
Driver: n/a
superstrikertwo
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
MP3 Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00600800,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Full Screen Renderer,0x00200000,1,0,,6.06.6000.16386
Multiple File Output,0x00200000,2,2,WMM2FILT.dll,
WMT Black Frame Generator,0x00200000,1,1,WMM2FILT.dll,
WMT Import Filter,0x00200000,0,1,WMM2FILT.dll,
DV Muxer,0x00400000,0,0,,6.06.6000.16386
Color Space Converter,0x00400001,1,1,,6.06.6000.16386
WMT Interlacer,0x00200000,1,1,WMM2FILT.dll,
WM ASF Reader,0x00400000,0,0,,11.00.6000.6324
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.6000.6324
AVI Splitter,0x00600000,1,1,,6.06.6000.16386
VGA 16 Color Ditherer,0x00400000,1,1,,6.06.6000.16386
Microsoft MPEG-2 Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,11.00.5840.6324
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.6000.16386
WMT Format Conversion,0x00200000,1,1,WMM2FILT.dll,
9x8Resize,0x00200000,1,1,WMM2FILT.dll,
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.6000.16386
WMT Virtual Source,0x00200000,0,1,WMM2FILT.dll,
Microsoft TV Caption Decoder,0x00200001,1,0,MSTVCapn.dll,6.00.6000.16386
MJPEG Decompressor,0x00600000,1,1,,6.06.6000.16386
CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.00.6000.16386
MPEG-I Stream Splitter,0x00600000,1,2,,6.06.6000.16386
SAMI (CC) Parser,0x00400000,1,1,,6.06.6000.16386
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.6000.16386
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.6000.16386
WMT AudioAnalyzer,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-2 Video Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6000.6324
Stretch Video,0x00200000,1,1,WMM2FILT.dll,
Internal Script Command Renderer,0x00800001,1,0,,6.06.6000.16386
MPEG Audio Decoder,0x03680001,1,1,,6.06.6000.16386
DV Splitter,0x00600000,1,2,,6.06.6000.16386
Video Mixing Renderer 9,0x00200000,1,0,,6.06.6000.16386
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,11.00.6000.6324
Frame Eater,0x00200000,1,1,WMM2FILT.dll,
Allocator Fix,0x00200000,1,1,WMM2FILT.dll,
ACM Wrapper,0x00600000,1,1,,6.06.6000.16386
Video Renderer,0x00800001,1,0,,6.06.6000.16386
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.6000.16386
Capture ASF Writer,0x00200000,0,0,WMM2FILT.dll,
Line 21 Decoder,0x00600000,1,1,,6.06.6000.16386
Video Port Manager,0x00600000,2,1,,6.06.6000.16386
Video Renderer,0x00400000,1,0,,6.06.6000.16386
Bitmap Generate,0x00200000,1,1,WMM2FILT.dll,
Proxy Sink,0x00200000,1,0,WMM2FILT.dll,
Proxy Source,0x00200000,0,1,WMM2FILT.dll,
WM ASF Writer,0x00400000,0,0,,11.00.6000.6324
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.00.6000.16386
WMT Sample Information Filter,0x00200000,1,1,WMM2FILT.dll,
File writer,0x00200000,1,0,,6.06.6000.16386
DVD Navigator,0x00200000,0,3,,6.06.6000.16386
WMT DV Extract,0x00200000,1,1,WMM2FILT.dll,
Overlay Mixer2,0x00200000,1,1,,6.06.6000.16386
AVI Draw,0x00600064,9,1,,6.06.6000.16386
Microsoft MPEG-2 Audio Encoder,0x00200000,2,0,msmpeg2enc.dll,11.00.6000.6324
WST Pager,0x00800000,1,1,WSTPager.ax,6.06.6000.16386
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.6000.16386
Record Queue,0x00200000,1,1,WMM2FILT.dll,
DV Video Decoder,0x00800000,1,1,,6.06.6000.16386
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.6000.16386
Null Renderer,0x00200000,1,0,qedit.dll,6.06.6000.16386
WMT Log Filter,0x00200000,1,1,WMM2FILT.dll,
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.6000.16386
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,11.00.6000.6324
WMT Virtual Renderer,0x00200000,1,0,WMM2FILT.dll,
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.6000.16386
Smart Tee,0x00200000,1,2,,6.06.6000.16386
Overlay Mixer,0x00200000,0,0,,6.06.6000.16386
AVI Decompressor,0x00600000,1,1,,6.06.6000.16386
WMT MuxDeMux Filter,0x00200000,0,0,WMM2FILT.dll,
NetBridge,0x00200000,2,0,netbridge.dll,6.01.6000.16386
AVI/WAV File Source,0x00400000,0,2,,6.06.6000.16386
WMT Volume,0x00200000,1,1,WMM2FILT.dll,
Wave Parser,0x00400000,1,1,,6.06.6000.16386
MIDI Parser,0x00400000,1,1,,6.06.6000.16386
Multi-file Parser,0x00400000,1,1,,6.06.6000.16386
File stream renderer,0x00400000,1,1,,6.06.6000.16386
WMT VIH2 Fix,0x00200000,1,1,WMM2FILT.dll,
Microsoft MPEG-1/DD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,11.00.5840.6324
AVI Mux,0x00200000,1,0,,6.06.6000.16386
Line 21 Decoder 2,0x00600002,1,1,,6.06.6000.16386
File Source (Async.),0x00400000,0,1,,6.06.6000.16386
File Source (URL),0x00400000,0,1,,6.06.6000.16386
Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.6000.16386
AudioRecorder WAV Dest,0x00200000,0,0,,6.00.6000.16386
AudioRecorder Wave Form,0x00200000,0,0,,6.00.6000.16386
SoundRecorder Null Renderer,0x00200000,0,0,,6.00.6000.16386
Infinite Pin Tee Filter,0x00200000,1,1,,6.06.6000.16386
WMT Switch Filter,0x00200000,1,1,WMM2FILT.dll,
Enhanced Video Renderer,0x00200000,1,0,evr.dll,5.00.0001.0001
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,WMM2FILT.dll,
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.6000.16386
MPEG Video Decoder,0x40000001,1,1,,6.06.6000.16386
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,6.00.6000.16386
WDM Streaming Data Transforms:
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,6.00.6000.16386
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,,6.06.6000.16386
MJPEG Compressor,0x00200000,0,0,,6.06.6000.16386
Cinepak Codec by Radius,0x00200000,1,1,,6.06.6000.16386
Intel IYUV codec,0x00200000,1,1,,6.06.6000.16386
Microsoft RLE,0x00200000,1,1,,6.06.6000.16386
Microsoft Video 1,0x00200000,1,1,,6.06.6000.16386
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IMA ADPCM,0x00200000,1,1,,6.06.6000.16386
Microsoft ADPCM,0x00200000,1,1,,6.06.6000.16386
GSM 6.10,0x00200000,1,1,,6.06.6000.16386
CCITT A-Law,0x00200000,1,1,,6.06.6000.16386
CCITT u-Law,0x00200000,1,1,,6.06.6000.16386
MPEG Layer-3,0x00200000,1,1,,6.06.6000.16386
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,,6.06.6000.16386
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.6000.16386
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.6000.16386
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.6000.16386
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.6000.16386
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,EncDec.dll,6.06.6000.16386
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.6000.16386
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.6000.16386
WDM Streaming Communication Transforms:
Audio Renderers:
Default DirectSound Device,0x00800000,1,0,,6.06.6000.16386
Default WaveOut Device,0x00200000,1,0,,6.06.6000.16386
U
Unregistered
Guest
i have the same problem im finna call these freakin people this is makin me mad
