The thread discusses how to modify a script originally designed to open links in Chrome to instead open them in Microsoft Edge. The original poster tries different methods, including using `ShellExecute` and `Run`, but encounters issues with launching URLs correctly in Edge. A respondent suggests using PowerShell's `Start-Process` with the appropriate arguments, but the original poster clarifies that their script is in VBScript and is calling a subroutine with URLs. The main conclusion is that integrating PowerShell commands into VBScript requires careful handling, and the user needs to adapt their script accordingly to successfully open URLs in Edge. The overall sentiment indicates troubleshooting and experimentation to achieve proper URL launches within their scripting environment.
Carenn12
Member
Currently I am using this script to open links in Chrome:
Sub Chrome(URL)
' Purpose: Launch Chrome
' Arguments: <URL>
if (ubound(split(URL," ")) = 0) then
Dim objShell
Set objShell = CreateObject("Shell.Application")
objShell.ShellExecute "chrome.exe", URL, "", "", 1
end if
end Sub
Is it possible to open this in Microsoft Edge? I tried replacing shellExecute line with this objShell.ShellExecute "microsoft-edge:", URL, "", "", 1, but that just opens the Edge with home page, and not the `URL`. Any tips?
Thanks! Had to do some small adjustments, but this works like a charm:
Dim shell
Set Shell = CreateObject("WScript.Shell")
Shell.Run """" & "microsoft-edge:" & URL & """"
Neemobeer
Windows Forum Team
Set objShell = CreateObject("WScript.Shell")
objShell.Run "msedge URL"
should work
Neemobeer
Windows Forum Team
Works for me, what version of Windows? Can you use powershell instead?
Neemobeer
Windows Forum Team
It's depends how it needs to be called.
If it's a hard coded call then like this
Start-Process -FilePath "msedge" -ArgumentList "https://google.com"
Carenn12
Member
Thread Author #8
So like this?:
Sub Chrome(URL)
' Arguments: <URL>
  Start-Process -FilePath "msedge" -ArgumentList "URL"
end if
end Sub
Neemobeer
Windows Forum Team
No you're mixing vbs and powershell. It's just the one line
Carenn12
Member
Thread Author #10
But there are multiple function in my .vbs file that contains lines like this:
Chrome "https://domain.my.salesforce.com/apex/ScreenPopView?nr=&cID=" + Params.ParamByName("cID") + "&crpnr=" + NR
And that
Chrome
is connected and runs by the
Sub Chrome(URL)
. Do you mean I should replace that Chrome in front of the link with this line:
That does not pop the url.
Neemobeer
Windows Forum Team
Visual Basic and PowerShell are different languages you can't mix the code in a script. I was suggesting to just convert your code to Powershell, it's much simpler to write.
Carenn12
Member
Thread Author #12
The .vbs file is 4000 lines of code, so I was hoping to find a easier solution.
Neemobeer
Windows Forum Team
Some slight modification to the original code I suggested (VBS)
Dim URL
URL = "https://google.com"
Dim shell
Shell.Run """" & "microsoft-edge://" & URL & """"
Carenn12
Member
Thread Author #14
Dim shell
Neemobeer
Windows Forum Team
Probably a difference in Windows 10 versions. Both microsoft-edge: and microsoft-edge:// work on mine
Neemobeer
Windows Forum Team
Still would be a good learning opportunity to convert that script to powershell. I imagine that 4000+ line script would end up half the size maybe less.
