Henrythesecond
Hi @WindowsForum AI ,
The Bing AI instructions for adding a Feature, OpenSSH, says to use System-Optional Features and Add. But there isn't an add function that I can find.
Thanks for the build details—that helps.
On Windows 11, Add-WindowsCapability can look “stuck” while it downloads from Windows Update. Don’t rely on Task Manager for progress. Do this:
  1. Check if it’s already installed or pending
  • Run (non-admin is fine):
    Get-WindowsCapability -Online -Name OpenSSH.Client* | ft Name,State
  • If State = Installed, you’re done: run ssh -V.
  • If State = InstallPending, just Restart Windows and test again.
  1. If it shows NotPresent or the install appears hung
  • Cancel the current PowerShell with Ctrl+C, then Restart.
  • In an elevated terminal run (shows progress and fixes component store issues):
    DISM /Online /Cleanup-Image /RestoreHealth
    DISM /Online...
    DISM /Online /Add-Capability /CapabilityName:OpenSSH.Client~~~~0.0.1.0
  • Make sure required services are running:
    Get-Service wuauserv,bits,TrustedInstaller | ft Name,Status
    # If any are Stopped:
    Start-Service wuauserv; Start-Service bits; Start-Service TrustedInstaller
  • Ensure the connection isn’t metered (metered can block capability downloads):
    Settings > Network & internet > your network > turn off Metered connection.
    Or check:
    Get-NetConnectionProfile | ft Name,IsMetered
  1. If it still won’t progress (no percentage after a few minutes)
  • Install from local media (no internet needed). Mount the Windows 11 24H2 “Features on Demand” ISO that matches your build 26100, note the drive letter (e.g., D:), then:
    DISM /Online /Add-Capability /CapabilityName:OpenSSH.Client~~~~0.0.1.0 /Source:D:\ /LimitAccess
  1. Verify
    where ssh
    ssh -V
    If it errors instead of hanging, please share the exact State from Get-WindowsCapability and any DISM error code/percent you see.
Why you don’t see “Add”​
That guidance is a bit out of date. In current Windows 11/10, the path is Settings > Apps > Optional features, and the old “Add” button is now labeled “View features.” If OpenSSH Client is already installed, you’ll only see it under Installed features (so no “Add”/“View features” prompt for it).
Add OpenSSH via Settings (GUI)​
  • Open Settings > Apps > Optional features.
  • Click View features (under “Add an optional feature”).
  • Search for “OpenSSH” and check:
    • OpenSSH Client (recommended)
    • OpenSSH Server (only if you need to accept incoming SSH connections)
  • Click Next > Install, then wait a minute. Verify with: open Windows Terminal and run: ssh -V
If “View features” is missing/greyed out​
  • The feature may already be installed: look under Installed features for “OpenSSH Client/Server.”
  • Device is managed by policy: you might see “Some settings are managed by your organization.” In that case, use PowerShell below or contact your admin.
  • No internet/source: Windows may need Windows Update or a local source to add capabilities.
Add via PowerShell (works on Home/Pro/Enterprise)​
Run Windows Terminal (Admin) and execute:
# Client
Add-WindowsCapability -Online -Name OpenSSH.Client~~~~0.0.1.0 # Server (optional)
Add-WindowsCapability -Online -Name OpenSSH.Server~~~~0.0.1.0 # Start and enable SSH server (only if you installed Server)
Start-Service sshd
Set-Service -Name sshd -StartupType Automatic
Then test with:
ssh -V
What version of Windows are you running, and do you see “View features” on Settings > Apps > Optional features? If not, tell me exactly what you see on that page.
Henrythesecond
# Client
# Server (optional)
Start-Service sshd
Then test with:
ssh -V
Just quickly in Apps there is no Optional Features listed.
Let’s jump straight to it​
If “Optional features” isn’t visible under Settings > Apps, try the direct link:
  • Press Win+R, paste: ms-settings:optionalfeatures, and press Enter.
  • On Windows 10, it may appear as a link inside “Apps & features” (top of the page) labeled “Optional features” or “Manage optional features.”
If that page won’t open or is hidden by policy, install OpenSSH without the GUI:
  • Open Windows Terminal (Admin) and run:
    # (Optional server)
    # Add-WindowsCapability -Online -Name OpenSSH.Server~~~~0.0.1.0
    Then verify with:
    ssh -V
    Tip: On most Windows 11 systems the OpenSSH Client is already present at C:\Windows\System32\OpenSSH\ssh.exe.
Can you confirm your exact Windows version (run winver) and whether ms-settings:optionalfeatures opens for you? If it doesn’t, is this a work-managed PC that might hide Settings pages?
Henrythesecond
I started
Add-WindowsCapability -Online -Name OpenSSH.Client~~~~0.0.1.0<br>
but it looks like it is stalled, I don't any movement in the Task Manager
Edition Windows 11 Home
Version 24H2
Installed on ‎19/‎03/‎2025
OS build 26100.6584
Experience Windows Feature Experience Pack 1000.26100.234.0
Henrythesecond
Ok that took a really long time. I was trying your other suggestions in another terminal, but then noticed some progress.
Path :
Online : True
RestartNeeded : False
OpenSSH_for_Windows_9.5p2, LibreSSL 3.8.2
Looks good, so how do I get the GUI?
Do you want the Settings “Optional features” page or an SSH app UI?​
You’ve got OpenSSH installed. There are two “GUIs” you might be after:
1) The Windows Optional features GUI (to view/remove OpenSSH)
  • Open it directly: press Win+R and run: ms-settings:optionalfeatures
  • Or go to Settings > Apps > Optional features > Installed features, then find “OpenSSH Client”.
  • If “Optional features” still doesn’t appear, check if a policy is hiding Settings pages:
    • Run: reg query HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer /v SettingsPageVisibility
    • If a value exists that hides optionalfeatures/apps, tell me what it shows and I’ll help clear it.
2) A GUI for using SSH (instead of the ssh command)
  • PuTTY (lightweight), MobaXterm (tabbed SSH + built‑in SFTP), Termius/Tabby (modern UI), or WinSCP for drag‑and‑drop SFTP.
  • You can also make a one‑click SSH profile in Windows Terminal:
    • Windows Terminal > Settings (Ctrl+,) > Add new profile > Command line:
      C:\Windows\System32\OpenSSH\ssh.exe user@host -p 22
    • Name it, pick an icon, Save. Now it opens directly into that SSH session.
Which of those are you looking for—the Settings page, or a GUI client for SSH?
Henrythesecond
  • Open it directly: press Win+R and run: ms-settings:optionalfeatures worked going to Viw features.
  • But OnenSSH Client checkbox is only for removing.
That “remove” option means it’s already installed​
What you’re seeing is expected. In Optional features:
  • “Installed features” shows OpenSSH Client with only one action: Uninstall (i.e., remove).
  • “View features” (Add an optional feature) only lists items not already installed, so OpenSSH Client won’t appear there once it’s installed.
What do you want to do next?​
  • Reinstall the client via GUI:
    1) Settings > Apps > Optional features > Installed features > OpenSSH Client > Uninstall.
    2) Wait a minute, click View features, search “OpenSSH Client,” check it, Next > Install.
  • Add the server (if you need inbound SSH):
    1) View features > search “OpenSSH Server” > Install.
    2) Then enable the service: open Services (services.msc) > sshd > Start, and set Startup type to Automatic.
  • Use a GUI for SSH sessions (instead of the ssh command): install PuTTY, MobaXterm, or create a profile in Windows Terminal pointing to C:\Windows\System32\OpenSSH\ssh.exe user@host.
If you tell me whether you want to reinstall, add the server, or use a GUI client, I’ll give exact steps for that path.
Henrythesecond
So it looks like ssh is available:
PS C:\Users\henle> ssh -V
But it is still not accepting my password.
Got it—SSH works. If you’re seeing a password prompt, that’s controlled by the server you’re connecting to. You have two options:
  • Client-only (just for your sessions): Refuse password from the client so it will only try keys.
    • One time: ssh -o PasswordAuthentication=no user@host
    • Permanent for a host: create %USERPROFILE%.ssh\config with:
      Host myserver
      HostName host.example.com
      User youruser
      PasswordAuthentication no
  • Server-side (actually disable password logins for everyone):
    • If the server is THIS Windows PC (OpenSSH Server installed):
      1) Put your public key in C:\Users\YourUser.ssh\authorized_keys (create the .ssh folder if needed).
      Permissions (important):
      PowerShell (Admin):
      icacls "$env:USERPROFILE.ssh" /inheritance:r
      icacls "$env:USERPROFILE.ssh" /grant "$env:USERNAME:(F)"
      icacls "$env:USERPROFILE.ssh\authorized_keys" /inheritance:r
      icacls "$env:USERPROFILE.ssh\authorized_keys" /grant "$env:USERNAME:(F)"
      2) Edit C:\ProgramData\ssh\sshd_config (run Notepad as admin) and set:
      PubkeyAuthentication yes
      KbdInteractiveAuthentication no
      Optional: require keys only​
      AuthenticationMethods publickey
      3) Restart the service:
      Restart-Service sshd
      4) Test from another window before closing your current session:
      ssh -o PasswordAuthentication=no -v youruser@localhost
    • If the server is Linux/Unix: edit /etc/ssh/sshd_config with the same lines (PasswordAuthentication no, PubkeyAuthentication yes, optionally KbdInteractiveAuthentication no / AuthenticationMethods publickey), then sudo systemctl restart sshd and test.
Quick question to confirm: are you connecting to a remote server, or is your Windows 11 PC running OpenSSH Server and you want to lock it down?
