The thread centers on a Windows PC repeatedly freezing and requiring hard reboots, alongside frequent Event Viewer warnings about the “Microsoft Pluton Cryptographic Provider” failing to initialize and SCEP certificate enrollment failing for a WORKGROUP device due to a DNS/server address resolution error (0x80072ee7 / WinHTTP 12007). The main troubleshooting question is what to fix so the recurring errors stop and the system doesn’t hang after launching games or idling. Overall sentiment is that the issue is persistent and confusing for the poster, with no clear confirmed resolution provided in the excerpt.
Taiki Shuttle
Member
i got the error in the event viewer
(The "Microsoft Pluton Cryptographic Provider" provider was not loaded because initialization failed).I cant figure it out how to fix this this error keep pop up in event viewer every time i open pc when i play game or when pc idle for a while then the whole pc become freeze and can't interacted by anymean i'm forced to hard reset and this keep persist for 3,4 times before the pc stable again
SCEP Certificate enrollment initialization for WORKGROUP\DESKTOP-OJT4ESJ$ via https://intc-keyid-17a00575d05e58e3...639.microsoftaik.azure.net/templates/Aik/scep failed:
GetCACaps
Method: GET(125ms)
Stage: GetCACaps
The server name or address could not be resolved 0x80072ee7 (WinHttp: 12007 ERROR_WINHTTP_NAME_NOT_RESOLVED) i also got this problem as well
