The original poster, gray123, reports their Compaq Presario SR5490AN periodically returning to the startup screen after several hours of use, especially when idle. ChatGPT suggests troubleshooting steps including checking power settings, updating drivers, monitoring for overheating, disabling sleep mode, running system maintenance, and checking for malware. The overall advice aims to identify whether software or hardware issues are causing the system to revert unexpectedly, encouraging backup and professional help if needed.
gray123
i have a compaq presario sr5490an quad core win 7 ultimate x64 everything runs well but for some reason after time like 3 to 6 hours or less in just drops to the start up screen were u press f10 [bios] [boot screen] not sure what its called can anyone help me ps it seems to happen quicker if the pc is not being used left on desktop
It seems like your Compaq Presario SR5490AN is experiencing an issue where it suddenly goes back to the startup screen after a few hours of use, especially if it's left idle on the desktop. This could be caused by several factors, including power settings, system updates, or hardware issues. Here are a few steps you can take to troubleshoot and potentially resolve this issue:
Troubleshooting Steps:​
  • Check Power Settings:
  • Make sure that your power settings are configured correctly to prevent the system from going into sleep mode or hibernating inadvertently.
  • Update Drivers:
  • Ensure that all your drivers, especially graphics and chipset drivers, are up-to-date. Outdated drivers can sometimes cause system...
  • Update Drivers:
  • Ensure that all your drivers, especially graphics and chipset drivers, are up-to-date. Outdated drivers can sometimes cause system instability.
  • Check for Overheating:
  • Check if the system is overheating. Ensure that the vents are clear of dust and debris and that the fans are working properly.
  • Disable Sleep Mode:
  • Disable sleep mode and hibernation settings temporarily to see if the issue persists.
  • Run System Maintenance:
  • Perform a disk cleanup, check for system errors, and defragment your hard drive to maintain system performance.
  • Monitor System Resources:
  • Use Task Manager to monitor system resources to see if any specific process is causing the issue.
  • Check for Malware:
  • Run a full system scan using a reliable antivirus software to check for any malware or viruses that might be causing the issue.
  • Update Windows:
  • Make sure Windows Update is enabled and all the latest updates are installed. Sometimes, system updates can address underlying issues.
  • Check Event Viewer:
  • Look in the Event Viewer for any error messages or warnings that might give you more insight into what's causing the problem.
    Additional Information:​
  • It is also recommended to backup your important files regularly to prevent data loss in case of unexpected issues.
  • If the problem persists after trying these steps, you may need to seek professional assistance to diagnose any potential hardware problems. By following these steps, you can hopefully identify and resolve the issue causing your Compaq Presario to revert to the startup screen unexpectedly.
