The thread discusses how to optimize Windows power settings for intensive tasks like video editing. The original poster seeks advice on whether to disable sleep/hibernation and how processor and hard disk settings might affect performance. The response recommends disabling sleep and hibernation, setting the processor to run at 100%, and using a high-performance power plan to maximize efficiency during demanding video editing tasks.
Leo
Member
Hi everybody,
I use my computer for video editing which is a heavy computational task and can take hours to complete. What power options should be selected for this kind of a task? As far as I understand, sleeping and hibernation should be disabled completely. But what about Hard Disk and processor? If I understand correctly, hard Disk will not go to sleep if it is being used by a program, so there is no need to disable turning Hard Disk off after a certain time. And in the Processor power management section there is "Minimum processor state" which is set to 5% by default. Should I leave it as it is or will setting it to 100% increase the speed of video processing? Any other recommendations regarding power management?
When using your computer for video editing, especially for long and intensive tasks, optimizing the power settings can help improve performance and avoid interruptions. Here are some recommendations for power settings: 1. Sleep and Hibernation: - Disable sleep and hibernation modes to prevent your computer from going into low-power states automatically. These interruptions can halt video editing tasks and cause delays. 2. Hard Disk: - You are correct that modern hard drives usually stay active during tasks, so disabling hard disk sleep may not be necessary. However, for SSDs (Solid State Drives), which are commonly used as boot drives, you might not have many benefits from allowing them to sleep. 3. Processor Power...
When using your computer for video editing, especially for long and intensive tasks, optimizing the power settings can help improve performance and avoid interruptions. Here are some recommendations for power settings: 1. Sleep and Hibernation: - Disable sleep and hibernation modes to prevent your computer from going into low-power states automatically. These interruptions can halt video editing tasks and cause delays. 2. Hard Disk: - You are correct that modern hard drives usually stay active during tasks, so disabling hard disk sleep may not be necessary. However, for SSDs (Solid State Drives), which are commonly used as boot drives, you might not have many benefits from allowing them to sleep. 3. Processor Power Management: - Adjusting the "Minimum processor state" can impact the speed of video processing. Setting it to 100% ensures that the processor runs at full capacity, which can be helpful during demanding tasks like video editing. This setting prevents the processor from throttling down due to low usage, ensuring maximum performance. 4. Cooling: - Ensure that your computer has adequate cooling. Video editing tasks can stress the CPU and GPU, leading to increased heat generation. Proper ventilation and cooling can help maintain optimal performance and prevent overheating, which can cause throttling. 5. Display and Background Apps: - Consider dimming the monitor brightness or turning off the screen during long rendering tasks to save power. Also, close unnecessary background applications to free up system resources for video editing software. 6. Power Plan: - Using a High-Performance power plan can ensure that the system operates at maximum performance levels. This power plan prevents underclocking or power-saving features that may interfere with video editing tasks. By optimizing these power settings, you can create an environment that supports uninterrupted and efficient video editing on your computer.
