pstein
When I want to open a file or folder from programs I go oftentimes to a menu
File--->Open
Which in turn calls the default FileOpenDialog dialog box.
This worked successfully on 64bit Win7 here in the past.
However when I do this in certain (but not all!!!) Office programs like Excel 2007 now then
the call is runnning forever (=the cursor indicates in progress).
Whats wrong?
No, I don't have open network connections.
Curiously for other programs it works.
Is it due to one of the last Microsoft patches?
Peter
If you're experiencing delays or issues with File Open dialogs in certain Office programs like Excel 2007 on your 64-bit Windows 7 system, here are some troubleshooting steps you can try:
Troubleshooting Steps:​
  • Disable Add-ins:
  • Disable any Excel add-ins and extensions that might be causing conflicts. Add-ins can sometimes interfere with the smooth operation of certain functions.
  • Office Repair:
  • Perform a repair of your Office installation. This can help fix any corrupted files that might be causing the issue.
  • Update Office:
  • Ensure that your Office 2007 installation is up to date with the latest updates and patches. Microsoft releases updates to fix known issues.
  • Check Antivirus...
  • Disable Add-ins:
  • Office Repair:
  • Update Office:
  • Check Antivirus Software:
  • Your antivirus software might be scanning the dialog creation process, causing delays. Try disabling real-time scanning temporarily to check if it resolves the issue.
  • System File Checker:
  • Run a System File Checker scan to check for and repair corrupted system files that could be impacting the File Open dialog.
  • Clean Boot:
  • Perform a clean boot of your system to rule out any third-party software conflicts.
  • Check Windows Updates:
  • Check if any recent Windows updates might have caused the issue. Rolling back recent updates can help isolate the problem.
  • Office Compatibility Mode:
  • Ensure that Office 2007 is running in compatibility mode for Windows 7. Right-click on the Excel shortcut, go to Properties, and under the Compatibility tab, set compatibility mode.
  • Reinstall MS Office:
  • If all else fails, consider reinstalling Office 2007 to ensure a clean installation. By following these steps, you should be able to troubleshoot and potentially resolve the issue with the File Open dialog in certain Office programs on your Windows 7 system. If the problem persists or you need further assistance, feel free to ask for more help.
