Aluria
Hello, for the past 3 days I’ve been trying to open up a program on my computer called AdvSubmitter-v4.5-Registered the program worked perfectly fine when I was running on my windows xp desktop but now I just don’t know what’s going on, I’ve tried the troubleshoot compatibility program and tried to make it windows xp sp2 and windows xp sp3 mode but nothing I open the program confirm I want to open it and then nothing the program never opens.
However when I install AdvSubmitter-v4.5-Unregistered it installs fine but when I open it I get the following message:
“Error: Runtime error 216 at 0290704Aâ€Â￾
And the other weird thing when I check my task manager the programs don’t show up under the applications tab but show up under the processes tab.
Can anyone help me figure what’s going on and how to get the advanced submitter to work properly so I can get back to work
It seems like you are encountering issues with running AdvSubmitter-v4.5-Registered on your current Windows system. The error you mentioned, "Runtime error 216 at 0290704A," indicates a problem that needs to be addressed to run the program successfully. Here are some steps you can take to troubleshoot and resolve this issue: 1. Compatibility Mode Settings: - Since you've already tried running the program in compatibility mode for Windows XP SP2 and SP3 without success, you can attempt to run it in compatibility mode for an earlier version of Windows like Windows 98 or Windows 2000. 2. Administrator Privileges: - Ensure that you are running the program with administrator privileges. Right-click on the program shortcut or...
It seems like you are encountering issues with running AdvSubmitter-v4.5-Registered on your current Windows system. The error you mentioned, "Runtime error 216 at 0290704A," indicates a problem that needs to be addressed to run the program successfully. Here are some steps you can take to troubleshoot and resolve this issue: 1. Compatibility Mode Settings: - Since you've already tried running the program in compatibility mode for Windows XP SP2 and SP3 without success, you can attempt to run it in compatibility mode for an earlier version of Windows like Windows 98 or Windows 2000. 2. Administrator Privileges: - Ensure that you are running the program with administrator privileges. Right-click on the program shortcut or executable file and select "Run as administrator." 3. Check System Files: - Run a system file checker scan to check for any corrupted system files that might be affecting the program's functionality. Open Command Prompt as an administrator and run the command sfc /scannow. 4. Anti-Virus Scan: - Perform a full system scan with your antivirus software to rule out any malware or virus-related issues that could be causing the runtime error. 5. Update Windows: - Make sure your Windows operating system is up to date. Install any pending updates through Windows Update to ensure compatibility with the program. 6. Check Dependencies: - Verify if the program relies on any specific libraries or frameworks that may need to be installed or updated. Ensure all necessary dependencies are met. 7. Reinstall the Program: - If none of the above steps work, try uninstalling the program completely and then reinstalling it. Make sure to download the latest version compatible with your current Windows system. By following these steps, you should be able to troubleshoot the issues preventing AdvSubmitter-v4.5-Registered from running properly on your computer. If the problem persists, feel free to provide more details for further assistance!
